Pentax Q: Distortion correction for RAW shots with Apple Aperture?
Started Nov 27, 2012 | Questions
Rosember Senior Member • Posts: 1,950
I am very much enjoying my newly bought Q with 01 prime. For post processing of the RAW files I use Apple Aperture (newest version). Unfortunately, Aperture has no integrated distortion correction. Thus my Q-01-shots at times show very visible distortion. Any idea how to prevent this?
I already tried PTlens but the result is not convincing and the plug-in states the Q was not calibrated although PTlens claims to have calibrated all Q lenses (or at least the 01 and 02).
The distortion in the RAW images is not a game stopper for me, yet, any help would be appreciated. Thanks.
 Rosember's gear list:Rosember's gear list
Pentax K20D Pentax Q Pentax K-3 Pentax smc DA* 55mm F1.4 SDM Pentax smc DA 35mm F2.8 Macro Limited +4 more
Hythloday Senior Member • Posts: 2,032
Re: Pentax Q: Distortion correction for RAW shots with Apple Aperture?
I supplied the pictures for the Pentax Q lenses you mentioned. PTLens works correctly under PSE 11. You should select RAW and not JPEG. The lenses were corrected for 4:3 images.
OP Rosember Senior Member • Posts: 1,950
Thanks for your comment. I used the PTLens plug-in (latest version) for Aperture - and, unfortunately, it did not work. The stand alone version seems to be doing what it should, though. I will give it another try tomorrow.
Zvonimir Tosic
Zvonimir Tosic Senior Member • Posts: 2,778
No, Apple does not support even Aperture
Aperture was great a few years back, but Apple isn't doing anything to pace the fast moving imaging world, especially in smaller sensor / bridge camera market which is flourishing since the last two years and in which image quality has increased radically.
It takes a year, or more, for some cameras to get a proper support. Also, today's obvious things like lens distortions corrections are not included in Aperture, nor people have any clue about the schedule of updates of the software — whether their cameras will be supported in Aperture or does the Aperture has any update path at all.
On the other hand, if you're shooting with a Pentax DSLR that supports DNG, things are a bit brighter, albeit not perfect, because basics for large sensor imaging were nailed down and are slower to change (Fuji's new APS-C sensor being an exception).
They say camera manufacturers make their own camera obsolete, but Apple makes them unusable.
Zvonimir Tosic
“A portrait is not made in the camera, but on either side of it.”
— Edward Steichen
I tried the PTLens plug-in today again - without success. The plug-in seems to be broken for the Q, but at least the stand alone version works.
Re: No, Apple does not support even Aperture
I am afraid you might be right, Zvonimir. I am still hoping for an Aperture version 4, though, as I am very used to the program and really like the system integration and what it can do with RAW files.
Maybe, in the case of the Q and the broken PTLens plug-in, I should contact the makers of PTLens.
arnelie
arnelie Regular Member • Posts: 384
LR4 supports Q Prime 01
For your information, Light Room 4 supports distortion correction of Pentax Q Prime 01. I believe also 02 lens and others are supported, but I cannot verify this.
/Arne
 arnelie's gear list:arnelie's gear list
Ricoh GR II Pentax Q Pentax K-3 Pentax smc DA 21mm F3.2 AL Limited Sigma 17-50mm F2.8 EX DC OS HSM +10 more
Thomas Niemann Veteran Member • Posts: 4,354
PTLens update
The Aperture plug-in for PTLens has been fixed. An error in the release script. Just download/install again.
Thanks for keeping me on my toes, guys & gals!
Tom Niemann, Author PTLens
Re: PTLens update
Thanks, Tom! Works great now.
