X-F1 review
Started Nov 16, 2012 | Discussions
dv312
dv312 Veteran Member • Posts: 8,390
X-F1 review
 dv312's gear list:dv312's gear list
Fujifilm X-T3 Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 50-140mm F2.8 Fujifilm XF 100-400mm F4.5-5.6 OIS WR
IchiroCameraGuy Contributing Member • Posts: 888
Re: X-F1 review
Excellent review
 IchiroCameraGuy's gear list:IchiroCameraGuy's gear list
Canon EOS 500D Canon EOS M Samsung NX500 Canon EF 50mm f/1.8 II Canon EF-S 55-250mm f/4-5.6 IS II +2 more
brianj Forum Pro • Posts: 14,657
Re: X-F1 review
dv312 wrote:
Enjoy
http://blog.mingthein.com/2012/11/13/fuji-finepix-xf1/
Cheers
At last someone says how EXR should have worked, it could have produced seemless high quality under all conditions without any thought from the user about what machinations are going on inside.
From the review:
"What Fuji should have done is made an auto mode that maintains best perceptual image quality: in good light, shoot at 12MP, say up to ISO 800; in high contrast situations, automatically use DR400; finally, when the required ISO goes to say 1600 or above, then start binning pixels down to 6MP."
Brian
 brianj's gear list:brianj's gear list
Canon PowerShot ELPH 330 HS
Trevor G Veteran Member • Posts: 6,577
Re: X-F1 review
From the review:
Except that that information misses out on the most dramatic effect of EXR, which occurs in M size images:
  • the ability to hold at least 2EV of highlight information above 0EV when using DR400 (which is otherwise clipped away in JPEG or when using DR100)
  • the ability to recover that "hidden" highlight information using RAW software such as the bundled RFC/aka Silkypix.
In L size and M size when ISO is higher than DR, the unique sensor pixel pairing which occurs with the EXR sensor supposedly does not take place.  What's the point of an EXR sensor if you don't use it under the conditions it is designed for?
In L size it uses sensor amplification to "save" the highlight information once DR is set higher than 100, and this results in noisier images because ISO is raised to accomplish this.
Cheers
Trevor G
Silkypix tutorials at: http://photo.computerwyse.com
Re: X-F1 review
Trevor G wrote:
From the review:
That may be correct, and the review was only talking about full AUTO mode, so the expert user can still achieve all that is possible, if the scene hasn't already moved on, but for the average fuji P&S buyer the described simplification would make the camera straight forward to use.  Since the introduction of EXR I would never recommend a fuji camera to anyone I know because of the difficulty in mastering its many modes.  There is not a day goes by where we cannot find an example image on the fuji forum of someone blowing out a highlight even though they are using the best P&S for DR control.  Its a brilliant technical solution spoiled by the lack of simplification to the user. IMO
Brian
PAUL TILL
PAUL TILL Veteran Member • Posts: 9,286
Re: X-F1 review
It's not rocket science, how much easier do you want it? If you shoot at half resolution and DR400 you will have all the highlight control you could want, NO camera is capable of NEVER blowing out highlights.
Paul.
Re: X-F1 review
Paul.
Even on this forum experts can't even agree how EXR works in every detail.
I don't know anyone from the general public who would even know what dynamic range is !!  Most people don't even know that you don't need flash to shoot distant scenes in broad daylight, let alone how to actually turn it off.
The average person can't think far beyond the date of the next football match.
Brian
