Canon EF-S 15-85mm USM -- focus ring doesn't "stop"
Started Nov 13, 2012 | Discussions
Messiah Complex Regular Member • Posts: 133
My new 15-85 just arrived in the mail, and I notice that when I turn the focus ring, the distance scale will rotate as I would expect, however when it reaches the end of the scale, the focus ring will continue to turn, albeit a bit more stiffly.  I haven't tried for fear of compounding a problem, but it feels like it would continue in a full rotation.  This is my first USM lens; is this normal behaviour, or is something wrong?  It feels odd to me; I would have expected the ring to stop turning when it reaches the end of the focus range.
I'm at work, so I haven't had the chance to actually try the lens on my camera yet.
 Messiah Complex's gear list:Messiah Complex's gear list
Canon EOS 600D Canon EOS 70D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF-S 18-55mm f/3.5-5.6 IS II +3 more
nightfly Contributing Member • Posts: 567
Re: Canon EF-S 15-85mm USM -- focus ring doesn't "stop"
This is completely normal and exactly as it should be. No need to worry.
Enjoy your lens!
Andreas
Working on http://nightfly.square7.ch/i5
 nightfly's gear list:nightfly's gear list
Canon EOS 60D Canon EF 50mm F1.4 USM Canon EF-S 15-85mm f/3.5-5.6 IS USM Sigma 105mm F2.8 EX DG OS HSM Tamron SP 70-200mm F/2.8 Di VC USD +1 more
OP Messiah Complex Regular Member • Posts: 133
Okay, that's great to know.  Thanks
Limburger
Limburger Veteran Member • Posts: 7,841
I believe it's the FTM mechanism that works this way but you will see in the little top window when max. is reached. Enjoy I got the same lens it's great!
Cheers Mike
 Limburger's gear list:Limburger's gear list
Fujifilm FinePix X100 Canon EOS 7D Sony a7 Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm F4L USM +3 more
