apaflo
Re: Epson says this about power on/off
kcbeatty wrote:
"It is important to always turn your printer off by the power switch (not by a surge protector or power bar) when not in use, as this protects the printheads from exposure to air and dust which can cause blocked nozzles."
That "important" refers to the use the power switch as opposed to pulling the plug, if you are going to turn it off. It specifically allows the print head to be docked properly, which does protect if from exposure to air and dust. The problem is not whether the printer is on or off, but whether you might manage to remove power when the print head is not docked, and then leave the printer off with an undocked print head.
If the printer is left on, as soon as it goes to the idle mode the print head is docked, and is equally as protected from exposure to air and dust as it is when properly powered down. On or off makes no difference in that respect.
There are only two differences to powering down and not powering down. The first is that you "save" power. Literally pennies per year. It is miniscule and not worth as much as the wages to have someone walk across the room even one time to turn it off. The second difference can be very significant though, and is what you personally want to consider.
When powered back on the printer goes through a head maintenance procedure that includes a nozzle cleaning routine. It squirts a bit of ink through each nozzle, to clear any clogs. If the printer is turned off daily that becomes a very significant percentage of the ink usage. If the printer is inactive for weeks at a time it is not significant.
I have found through my usage the R1800 that it rarely clogs nozzles when I turn it off between printing days. The ink recommendations were their usual talking points that I would expect all printer manufacturers to make.
It is not turning it off as such that prevents clogs, but rather having it do a nozzle cleaning routine just prior to each use. You can accomplish exactly the same thing without ever turning it off.
You can save ink by doing a nozzle check rather than a nozzle clean before each printing day's work begins.
