Contax G lens on Nikon One: any experience ?
Started Nov 1, 2012 | Questions
cboudier Regular Member • Posts: 413
Hi everybody,
This is my first message in this forum.
I previously used several type of cameras: rangefinder, bridges, SLR, DSLR with big pro-lenses and now I'm fed up by weight, size and shutter sound... --> I just received my v1
I was wondering if someone had already mounted a Contax G lens on a Nikon One ?
I'm particularly interested in the Zeiss Sonnar 90mm/2.8...
The V1+90mm combo looks promising (sharp & small lens, thin adapter, but nothing about on the internet...
Thanks.
Christophe Boudier
 cboudier's gear list:cboudier's gear list
Nikon 1 V1 Nikon 1 Nikkor VR 10-30mm f/3.5-5.6 Nikon 1 Nikkor VR 30-110mm f/3.8-5.6 Nikon 1 Nikkor 10mm f/2.8 Nikon 1 Nikkor 18.5mm f/1.8 +1 more
Nikon 1 V1
anotherrich Regular Member • Posts: 436
Re: Contax G lens on Nikon One: any experience ?
There would need to be an adapter of some kind, and presumably the lens would be fully manual (no autofocus, VR or even metered-exposure control, and it would have to compete with the fully featured N1 Nikkors (such as the apparently excellent  30-110).
 anotherrich's gear list:anotherrich's gear list
Sigma DP1 Nikon 1 J1 Nikon Df Nikon 1 V3 +3 more
OP cboudier Regular Member • Posts: 413
You're right about fully manual process.
Actually, there is an adapter for Contax G lens to Nikon 1 mount (and may be from several maker).
Compared to the 30-110 @ 90/5.6, the Zeiss is 2.8... i.e. not the same league.
Christophe Boudier
cseiler Regular Member • Posts: 375
Interesting, but how do you focus? The focusing for the lens was AF or with a wheel on the camera, is there a trick I am missing?
There is a ring on the adapter to enable manual focusing.
But in fact, the ring is so close to the body that it may be tricky to use
Christophe Boudier
karlreed Senior Member • Posts: 1,837
Re: Contax G lens on Nikon One: The G lenses are extraordinary
The Zeiss lenses for the G series, made by Kyocera, were extraordinarily good.
The 90mm 2.8 is literally too sharp for portrait work, it would show every detail on the subject, good or bad.
There is no perceptible geometric distortion in any of the 28mm,45mm,90mm lenses.
The back-purtrusions on several of the lenses would probably mean they cannot be used for an N1, but, you'd need to check that.  See the link below for comments on their quality.
http://www.kenrockwell.com/contax/g-system.htm#lenses
Karl Reed
karl reed
 karlreed's gear list:karlreed's gear list
Sony RX100 IV Nikon D200 Nikon D750 Olympus E-M1 II Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR +6 more
