D700 faultless
Started Oct 29, 2012 | Discussions
camerashy Veteran Member • Posts: 3,503
D700 faultless
Most of the posts on here seem to be about D600 and D800 issues.  I'm more than happy with my faultless D700 and Nikons QA appears to have gone downhill since the D700 days.
Dave
pbase supporter at www.pbase.com/dav4184
for equipment see profile
 camerashy's gear list:camerashy's gear list
Nikon D800
Nikon D600 Nikon D700 Nikon D800
OP camerashy Veteran Member • Posts: 3,503
Re: D700 faultless
As also confirmed by Rutgerbus...LOL.
Nikon D800
Robin Casady Forum Pro • Posts: 12,898
Re: D700 & D800E faultless
My D700 had break-in oil (bought it two years ago). My D800E had break-in oil.
Otherwise, my D800E is faultless, as was my D700.
Lenses are another matter. Had to return two copies of Nikon 70-200mm f/2.8D VR G-AFS ED-IF lens to get a good one. Had to return two copies of AF-S Nikkor 24-70mm f/2.8G ED to get one good one. So, batting one out of three for those lenses. I suspect that part of the problem was B&H sending out returned lenses as new.
Prime85 Senior Member • Posts: 1,017
What is a good price to purchase a D700?
Rutgerbus Senior Member • Posts: 2,013
I bought mine 3 weeks ago as a combo deal with the stellar Nikkor 24-70mm f2.8 for €2500. It was a VAT-free deal, so I was lucky.
www.rutgerbus.nl
Photographic Moments
 Rutgerbus's gear list:Rutgerbus's gear list
Nikon D80 Nikon D700 Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR Nikon AF-S Nikkor 300mm f/4D ED-IF Nikon AF-S Nikkor 24-70mm f/2.8G ED +1 more
primeshooter
primeshooter Veteran Member • Posts: 4,605
well...
Dave
You are hearing a very select few people bi*ch and whine about the D800. My copy is 100% perfect. Also, you have to understand that the D800 is a tour de force, with the boundaries well and truly pushed out there. I can understand why there are a few small teething problems. In a year no one will even mention this and it'll be the same as the 700. I remember when people bi*ched about the D700 too mate...
Has the Tsunami anything to do with it
Has Nikons QA gone down the pan since the Tsunami and could they be trying to get the goods out before they have fully re-established themselves??
Nikon D800
Sportz101 Junior Member • Posts: 29
Re: D700 faultless
I feel the same way about my D3. I bought it used, and picked up a 35-70mm f/2.8 and an 80-200f/2.8 lens. Both lens are the push-pull type. I've had no issues with my D3. It was obviously used, but works like a charm. I've shot 6 basketball games (grade school), and 2 of my son's swim meets, and am still amazed at what that camera can do at ISO 6400!
I think Nikon makes a pretty good product, IMO.
 Sportz101's gear list:Sportz101's gear list
Nikon D3
I just sold mine for $1,600 with less than 10K actuations.
Re: Has the Tsunami anything to do with it
Your pure speculation can only be answered here by pure speculation. It is just as likely that the high resolution of the camera has revealed things that have always been present. It could be that some equipment in the Sendai plant was not properly calibrated after the earthquake. It could also be that tighter tolerances are required than ever before.
In the past it was well known that the outer AF points were not as reliable nor as accurate as the central points. People just shrugged it off and moved on. Now it seems that some want to raise it to the same level of alarm as deaths from uncontrolled acceleration, or flaming Pintos.
VadimOm Senior Member • Posts: 1,903
Re: D700 faultless
D700 was (and still is) an incredible camera. If it had dual card slot I would have never parted with it. Well, that and faulty hot shoe which Nikon wouldn't admit to...
John Motts Veteran Member • Posts: 5,494
Re: D700 faultless
Both of my D700s have had the faulty hotshoe at different times. The D700 is one of the most complete, well rounded digital cameras ever made, but it's not completely faultless.
engbert Senior Member • Posts: 2,740
Do you have any evidence?
www.pbase.com/bertramm pbase & dpreview supporter
 engbert's gear list:engbert's gear list
Sony Alpha a7R III Sony FE 50mm F1.8 Sony FE 100-400mm F4.5-5.6 Sony FE 24-105mm F4
henryp
henryp Veteran Member • Posts: 6,783
Ironic to read this and then to read, also from you:
I looked at every Nikon-related transaction from a "Robin Casady" from California in our sales database. I cannot find the lens purchases you mentioned. I'd be happy to investigate your pure speculation but to do so I'd need some way to identify the transactions in question. Feel free to use henryp[at]bhphoto.com and reference this thread when you do.
And, I don't speculate. I will rely on facts when they can be established.
Henry Posner
B&H Photo-Video
 henryp's gear list:henryp's gear list
Nikon D5000 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR +1 more
