OM-D + 75mm 1.8 perfect music event combination
Started Oct 29, 2012 | Discussions
Y_VDM Regular Member • Posts: 289
12
That's why I bought this lens. The combo is perfect : silent, compact, sharp wide open. Mostly around 2000 ISO, Raw - LR 4.2 processed
Yves VDM ------------------------------- ------- http://www.virtualgallery.be
 Y_VDM's gear list:Y_VDM's gear list
Fujifilm X-Pro2 Leica SL2 Leica Summicron-M 35mm f/2 ASPH Voigtlander 15mm F4.5 Super Wide Heliar Voigtlander 50mm F1.5 Nokton +4 more
faith_ps
faith_ps Senior Member • Posts: 1,102
Re: OM-D + 75mm 1.8 perfect music event combination
The new way of taking picture.
Love those shots.
Jakop
The saxophone is a very interesting machine, but I'm more interested in music.
Steve Lacy quotes
 faith_ps's gear list:faith_ps's gear list
Ricoh GR Digital Sigma DP3 Merrill Leica X Vario Olympus Stylus 1 Canon EOS 5D Mark II +17 more
Moti Veteran Member • Posts: 8,965
Very nice photos indeed showing again that the OMD is a very capable camera in the hands of a good photographer.
On the other hand, I'm not very sure about the 75mm 1.8. It is a fantastic lens but it's limited FOV and lack of versatility, makes it far from being the perfect lens for shooting musical events. at least for me.
There is no perfect lens for musical events because there are so many different situations and variables but generally speaking, if I have to choose one lens only to shoot a musical event with my OMD, it will always be the Panasonic  35-100 f2.8.
Cheers
Moti
Peter Norvig Regular Member • Posts: 102
I agree that the 35-100 is the best choice for one lens.  But if you can have three lenses, then the 20, 45, and 75 give you ample FOV coverage and 1.3 stops more light.
 Peter Norvig's gear list:Peter Norvig's gear list
Canon EOS 5D Mark III Olympus E-M1 Canon EOS 7D Mark II Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM +15 more
OP Y_VDM Regular Member • Posts: 289
thanks for your comments. I agree with the 35-100 f:2.8 (in the past I used the Canon L 70-200 f:2.8 for such events). Only a choice I made to avoid zooms and go to fixed lens when switching to m43
One of the downside of the Zuiko is that the red dot for the mounting is not embossed, making the lens changing more difficult. When I swapped for the pana 25 f:1.4, the embossed red dot helped a lot.
marike6 Veteran Member • Posts: 5,088
An f2.8 lens, particularly on m43 where cameras don't excel at high ISOs, is not the best choice.  On a FF DSLR like a D4/D800, a 70-200 2.8 is a decent choice, a fast 85 1.4 or 135 f2 is even better.  Depending on the lighting in the venue, lens speed may make all the difference in the world.
The difference between 200 mm and 150 mm is not that significant. The faster max aperture of the Olympus 75 is.
Enjoyed the series of images.
 marike6's gear list:marike6's gear list
Nikon Coolpix P330 Panasonic Lumix DMC-GH2 Nikon D800 Fujifilm X-E1 Panasonic Lumix G 20mm F1.7 ASPH +7 more
adbit New Member • Posts: 8
I just agree!
Some pics from Saturday...
tedolf
tedolf Forum Pro • Posts: 29,547
They all seem to be....
a bit underexposed. Also, sometimes your shutter speed (e.g. 1/60) was a bit too slow.  Most theatrical shooting needs to be done at ISO 3200 to get the shutter speeds and exposure needed.    Tedolph
 tedolf's gear list:tedolf's gear list
Olympus PEN E-P5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Samyang 7.5mm F3.5 Fisheye +9 more
HatWearingFool
HatWearingFool Senior Member • Posts: 2,758
I'd play with the exposure and lighten up the musicians more. I wouldn't call the images underexposed because you exposed to save highlights. However, I think more work needs to be done on the exposure in PP.
Also you chose a weird shutter speed. It’s too slow to deliver sharp images, too fast to convey energy or motion. Pictures just seem slightly blurry.
Nice work though. I've done a lot of concert work; it ain’t easy.
If you like my thoughts or shots check out my blog http://www.thefixedfocus.com
 HatWearingFool's gear list:HatWearingFool's gear list
Olympus PEN E-PM1 Fujifilm X-T20 Olympus M.Zuiko Digital 17mm 1:2.8 Pancake Fujifilm XF 18mm F2 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +3 more
(unknown member) Senior Member • Posts: 1,178
Wow~~!
Phenomenal shots.  Please quit showing us what the 75 1.8 can do, or I will soon be in the doghouse from buying one.
Peter Norvig wrote:
... But if you can have three lenses, then the 20, 45, and 75 give you ample FOV coverage and 1.3 stops more light.
In theory this is true. Practically when I am shooting a musical event, I have no time to change lenses. According to my experience, an f2.8 lens such as the 35-70, is fast enough for most of my concert needs so I am very happy to give up the 1.3 extra stop of the primes in order to gain the versatility and the flexibility that the only a zoom lens can provide.
Cheers
Moti
