Upgraded to GH2 from GH1 - some questions
Started Oct 27, 2012 | Discussions
amipal
amipal Contributing Member • Posts: 682
Bought the GH2 today at Park Cameras as a replacement for my sterling GH1 - she's been great over the years, but I wanted a bit more dynamic range and fast focussing. Anyway, I've been looking through the manual and settings, and have some questions which I hope you can answer/contribute to:
1. What does I.Resolution do? The manual isn't very specific.
2. Is Long Shtr NR beneficial? I'd have thought most noise could be dealt with in PP.
3. Is it better to save to sRGB or Adobe RGB? Apparently the latter has more colourspace available - would this be visible/usable in LR4?
Thanks for any assistance.
 amipal's gear list:amipal's gear list
Panasonic Lumix DMC-GH4 Panasonic Lumix DMC-GM5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +5 more
Panasonic Lumix DMC-GH1 Panasonic Lumix DMC-GH2
jalywol
jalywol Veteran Member • Posts: 9,091
Re: Upgraded to GH2 from GH1 - some questions
Imaging Resource has a good explanation with photo samples:
http://www.imaging-resource.com/PRODS/DMCGH2/DMCGH2A5.HTM   (scroll down til you get to the Intelligent Resolution section in the middle of the page for it).
Long Shutter NR is beneficial; I think it works only with exposures over 2 seconds, but you will have to look it up.  It maps the noise after you take a photo (via a second camera-driven exposure, which takes a little bit of time), and then subtracts that noise from the image. It's not used for normal exposures.
It depends on what you are going to be doing with the photos.  I use Adobe RGB since my work flow includes printing on a professional printer, and I find it easier to get more accurate results if I use the AdobeRGB from start to finish.  (Color workflow in my system includes an IPS monitor which I profile with a Spyder calibrator, then using specific papers in my printer that I have or can get printer profiles for).
However, if you are primarily posting to the web or viewing your prints on the computer, use sRGB.  Many viewing programs/browsers are not accurately able to utilize the AdobeRGB color space, so photos that use it may appear with color shifts when viewed on some systems.  I routinely convert my AdobeRGB to sRGB files now when I make copies that are going to be viewed on line....works much better that way.
You're welcome
-J
RickPick
RickPick Senior Member • Posts: 1,314
Agree with Jalywol but if you are shooting raw files (you mentioned LR which suggests you are) the colour space you set in the camera doesn't matter. You can choose the appropriate one for the output you want to produce within the software.
Rick
 RickPick's gear list:RickPick's gear list
Panasonic Lumix DMC-GH4 Panasonic Lumix DMC-GX85 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 Panasonic 12-35mm F2.8 +3 more
amipal
OP amipal Contributing Member • Posts: 682
Right, so this is a JPEG-only sharpening process by the look of things. A bit of a high-contrast edge-detect so leave the blank areas free of noise.
If read that GH2 RAWs have NR applied to them, so does this affect the RAW files in the same way? I may have to do some tests to see whether it is really required, or whether Lightroom can deal with it in a better way.
I understand now! So if I'm working with RAWs, it doesn't really matter - only affects the JPEGs saved in-camera. Any exported images I want printed could be saved to AdobeRGB through LR anyway!
Thanks for you response, very informative and helpful!
amipal
Thanks Rick. I'm still very much pro-RAW after years of using the GH1, so will probably stick with them for now!
