Your website is broken - Can't upload images
Started Oct 25, 2012 | Discussions
bondiblue Contributing Member • Posts: 879
Have been trying top upload an image to my gallery to enter to a challenge,
... but I am unable to upload.
After trying to start the upload half a dozen times, most times nothing happens. Occasionally I can get it to show "Preparing to upload" with the spinning clock thingie, but no upload takes place.
 bondiblue's gear list:bondiblue's gear list
Panasonic Lumix DMC-LX5 Panasonic Lumix DMC-GX85 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic 12-35mm F2.8 Panasonic Lumix G 25mm F1.7 ASPH +4 more
Joshua123
Joshua123 Regular Member • Posts: 335
Re: Your website is broken - Can't upload images
Just wait a while and try again.  This has happened to me.  Why???? ...who knows.
      Josh
 Joshua123's gear list:Joshua123's gear list
Nikon D300 Nikon D50 Nikon D7200 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +7 more
RaptorUK Veteran Member • Posts: 3,266
This happens because you do not vote frequently enough . . .
Take a look at my album . . . www.F1Album.com
 RaptorUK's gear list:RaptorUK's gear list
Nikon D3 Nikon D2X Nikon D1X Fujifilm FinePix S2 Pro Nikon AF-S Nikkor 200-400mm f/4G ED-IF VR +7 more
chrisby
chrisby Regular Member • Posts: 259
LOL!
 chrisby's gear list:chrisby's gear list
Panasonic Lumix DMC-TS3 Canon PowerShot G1 X Canon G3 X Canon G9 X II Canon EOS 40D +6 more
Scott Everett
Scott Everett dpreview Admin • Posts: 1,092
Let us know if you are still having issues.
 Scott Everett's gear list:Scott Everett's gear list
Canon EOS 5D Mark II Olympus E-1 +2 more
stevelilly
stevelilly Regular Member • Posts: 497
I have been having this issue for a couple of days now??
If you want a prettier picture, bring me a prettier face!
http://digitalman.smugmug.com/
 stevelilly's gear list:stevelilly's gear list
Sony RX10 IV Sony Alpha a7R III Sony FE 12-24mm F4 Sony FE 24-105mm F4 Sony FE 28mm F2 +1 more
Scott Everett
What browser and browser version are you using? Thanks~
dartymix1 Regular Member • Posts: 112
Re: Your website is broken - Can't upload images - also question on Px rule limitation
I am having the same problem.  Also, the rule for watches says that the picture can't be over 1,600 px on the longest side.  How do I make the picture to fit this?
Deleted pending purge Senior Member • Posts: 1,197
Hi, there are basically two ways, depending how you took your photo. Every photo editing program has two common tools: "crop" and "resize".
If there is much more in the image than the watch face, crop the image to show what's required, and save the outcome under different name (to keep the original). Then use "resize" tool to it, and set the longer size to 1600px or smaller. The shorter side will follow the original aspect.
If you took a macro photo of just the watch face and you're satisfied with your image content, just resize the image to 1600px or less (and save under different name to keep the original).
Process your image additionally (maybe contrast and color balance, don't forget to check the sharpness after each resizing), give it a proper title and enter the Challenge. Should be easy. Good Luck!
Fil
I keep truing to load photos.  I get a pop up saying that I need the updated version of Adobe.  I try to load it, and it loads, but never installs.
I can't imagine what would Adobe have to do with entering the images to either your gallery or the Challenges. Are you trying to upload from some photo-editing program? Is your browser somehow dependent on Adobe?
Without exact data on how you do your processing and upload, it's hard to offer any solution, but in all cases your photo-editor should only be used to produce some .JPEGs. The upload to the site, that's another thing entirely.
Maybe someone else could guess what's wrong.
I use one or several standalone programs to edit my images (none of those Adobe-produced), and save them to "DPR Upload" folder on HDD. Then I access this site via Firefox, log-in, enter the Challenge, and browse to that folder to pick the right entry (imagename.jpg). Nothing to do with anything made by Adobe in all that.
Fil
No, I am uploading from my pictures the way I always do.  The "add photo" button on the screen does not look right (it looks like it has writing through it).  When I try to add photos a pop up appears that says I have to update my adobe.  I go to adobe and update it, but it never takes.  Not sure what the problem is.
I tried my lap top and got the same thing.  Both are Apples, not sure if that matters.  I tried my PC from work and it seemed to work OK.
This is the message that I get.
The version of “Adobe Flash Player” on your system does not include the latest security updates and has been blocked. To continue using “Adobe Flash Player”, download an updated version from Adobe’s website.
Bernard909
Bernard909 Regular Member • Posts: 247
A Flash player (Adobe made) plugin is needed to upload otherwise it won't work.
For Chrome check one is activated (actually 3 are available) or none (about:plugins)
PanAAA Regular Member • Posts: 118
Unable to upload photos to my gallery more than one week ago.
Still trying now without success. Alrdy feedback to DPReview but no reply.
Updated to Firefox ver 17, still no success in photo upload.
Is it true must let the upload progress clock spin more than half hour?
I have let the upload spinning wheel turn for 40minutes; with no success in photo upload.
Then I logged-out.
barb_s
barb_s Contributing Member • Posts: 802
I have never found that to work. I have only found that waiting and trying the next day, and sometimes resize-ing the photo get's it to upload. This past week I had the same issue for 2 or 3  days and then it started working. I have no idea why this happens so often but I never change browsers, and it just seems to break and then fix itself on a whim.
Barb
 barb_s's gear list:barb_s's gear list
Panasonic Lumix DMC-ZS3 Sony RX100 III Leica Q Canon EOS 70D
