Difficult Spider Shot with SX40 HS
Started Oct 18, 2012 | Discussions
jasenj1 Junior Member • Posts: 45
This was a difficult shot to get. And it's still not perfectly in focus. I was standing about 2 meters from the spider (so as not to scare it). The auto focus wanted to go past the spider to the distant trees. Manual focus didn't want to focus close enough. Switching to Macro, the camera still couldn't pick up the small spider in the scene. And there's no manual macro focus.
Anyone have suggestions on how to get a small subject suspended like this?
Canon PowerShot SX40 HS
MarioV Veteran Member • Posts: 7,089
Re: Difficult Spider Shot with SX40 HS
You could try focusing on the branch next to it, then back to the spider.
 MarioV's gear list:MarioV's gear list
Nikon Coolpix P900 Canon G3 X Panasonic ZS100 Nikon D5200 Canon EOS M100 +4 more
PhilM oz Senior Member • Posts: 1,350
Looking at the web on the right side it looks like a big part of the problem is motion blur or camera shake.
The horizontal threads are reasonably well defined; but the vertical ones are smeared - indicating horizontal camera shake (or perhaps the web was being blown in the breeze).
1/40th of a second is probably too slow at full telephoto zoom without a tripod (or a lot of luck).
Try increasing the ISO to get a faster shutter speed - or an external flash.
Phil.
cnli Junior Member • Posts: 46
I own a SX30 and found same problem many times.  It happened mostly when shooting tiny object few feet away with zoom.  For black object or thing that can't provide a clear texture, I could understand the difficulty.  But sometimes it seems just the limitation of the lens (or simply it is the nature of long zoom?) that you cannot focus at certain distance with certain focal length.
I got this feeling because more often when I either step further away with more tele or move closer with shorter focal length, I'll get the focus right.  Could some one tell me if that was a wrong thinking.
 cnli's gear list:cnli's gear list
PowerShot SX700
VisionLight
VisionLight Veteran Member • Posts: 6,227
From what I find with my SX40, the secret is to fill the frame as much as possible with the spider. That is easiest by turning on the Digital 2.0 TC in the menu. This turns the lens into a 1680mm macro lens (do not turn the focusing to Macro, leave it on Normal) that can shoot from as little as 4½ feet away and give a field of view as little as 1¾" wide. It also increases the stabilization. Then use the focus assist button to zoom out and find the spider right in the middle of the focus box. Release the focus assist button to zoom in while holding the camera perfectly steady. Half press the shutter to attain final focus and then take the picture.
These are three handheld uncropped results using this technique, including one shot directly into the setting sun. The first two were the better of two attempts each. The setting sun shot was the best of three attempts:
Orb Weaver and prey shot in medium shade
Orb Weaver in full sunlight.
Same Orb Weaver shot directly into the setting sun
Hope this helps,
Vision
 VisionLight's gear list:VisionLight's gear list
Samsung NX1 Canon EOS M5 Sony a7R IV Canon EF 100-400mm f/4.5-5.6L IS USM Canon EF 100mm f/2.8 Macro USM +15 more
Brilliant! That might not help every situation but surely give great insight of how to fully utilize the functions & features provided by the camera.
Thanks a lot!
PowerShot SX700
OP jasenj1 Junior Member • Posts: 45
Thanks to all for the tips. Definitely a learning curve to using the long end of the zoom.
Here's the best I could do last night. Faster shutter speed. I went to full zoom and then moved back and forth to get the focus to lock on. I forgot about using the TC. Still challenging to get the focus to lock on.
Again, thanks for the tips.
tonyinport Contributing Member • Posts: 567
I just take several shots and hope one of them works.  Might want to make sure that our focus box is small as well.  Tony
 tonyinport's gear list:tonyinport's gear list
Canon PowerShot G12 Canon EOS Rebel T4i Canon EF-S 15-85mm f/3.5-5.6 IS USM
Now that is an interesting bit of information.  I'll have to try turning to the 2x.  Thanks for sharing!  Tony
Cheryl Meisel Veteran Member • Posts: 3,021
Ohhhhhh gosh that is a NICE SHOT!!!!!  CONGRATS!
Cherylm
“Vision without action is a daydream. Action without vision is a nightmare."
http://www.pbase.com/cherylm;
ARShutterbug
ARShutterbug Veteran Member • Posts: 8,993
No MF available in macro?
There's no manual focus override available when using the macro mode of the SX40?  It isn't available by continuing to press the down arrow button until it switches to macro focusing?
