Tripod Collar for 200L f/2.0
Started Oct 17, 2012 | Questions
PC Wheeler
PC Wheeler Forum Pro • Posts: 17,902
Is a tripod ring/collar needed for this lens when using with a tripod or monopod?  If so, what's a good (non-Canon!) source?
Phil
 PC Wheeler's gear list:PC Wheeler's gear list
Canon PowerShot ELPH 330 HS Panasonic ZS100 Sony RX10 IV
ed rader Veteran Member • Posts: 9,068
Re: Tripod Collar for 200L f/2.0
you need to ask?
 ed rader's gear list:ed rader's gear list
Canon EOS 80D Canon EOS 5D Mark IV Sigma 15mm F2.8 EX DG Diagonal Fisheye Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +4 more
PC Wheeler
OP PC Wheeler Forum Pro • Posts: 17,902
ed rader wrote:
you need to ask?
No. I spend all day thinking up silly questions
Since it weighs the same as a typical DSLR, seems it wouldn't matter which the tripod interfaced with. But I read someone's statement that a collar should be used. So I'm trying to get more input.
Phil
PC Wheeler
ed rader wrote:
 http://www.bhphotovideo.com/c/product/542292-REG/Canon_2297B002_Telephoto_EF_200mm_f_2L.html
Oops, my bad. Subject should have been 200L f/2.8 -- a much smaller lens. I posted this message correctly in the wrong forum (Canon 7D etc.) and goofed when I brought it over here.
Phil
i'd use a tripod collar if you are changing orientation while shooting and don't have an L bracket.  i actually have a used OEM canon tripod collar in black that i would sell to you if you decided you need one.
PC Wheeler
Re: Tripod Collar for 200L f/2.8
I appreciate the offer, Ed. Did a search on Amazon and it wasn't clear which collars worked and which would not.  My application, for tripod use, is mounting on a Vixen Polarie tracking mount to do astrophotos. The set up is: Tripod > Manfrotto Geared Head > Polarie aligned with North Pole > Ball mount > Canon 60Da > 200L f/2.8 (or other, all smaller, lenses like 50 f/2.8 II).
Once aligned Polarie is North-aligned, and camera is pointed to area to be photographed (say Orion Nebula) then the motions of the camera-lens will basically be the Earth's rotation rate -- very slow so minimal accelerations at the interface.
Likely I'll try it and if there are stability issues I'll look into a collar. Total load in lbs is limited to 2 kg (4.4 lbs) and with the ball mount, 60Da and 200L my total is 4.2 lbs, leaving 0.2 lbs for the collar.
Problem is that I won't get to test this until Nov.  My daughter is taking my Polarie, tripod, geared mount and ball mount and her 40D to AZ tomorrow. She should do well there with dark skies. Here (metro L.A., near the ocean) I have much light pollution to fight and misc. issues from moisture in the air. I do have an Astronomik CLS clip-in filter arriving from Oceanside tomorrow so I'll probably do a piggyback on my C5+ or just do some short shots from a fixed tripod to see how it all works before Nov.
Phil
good luck to you!
PC Wheeler
Now that I have the lens I know the answer. It's really overbalanced to the front by all that glass. So today I ordered a tripod mount (3rd party).
Phil
