EM5 vs XE1 (images)
Started Oct 10, 2012 | Discussions
MDGolfer Regular Member • Posts: 203
EM5 vs XE1 (images)
xe1 with 35mm 1.4
em5 with pana 25mm 1.4
Focus pointed at the quarter
JPG fine on both
non scientific
both lenses at f1.4, camera chose shutter speed
Fujifilm X-E1
simon
simon Senior Member • Posts: 2,351
Re: EM5 vs XE1 (images)
I'm amazed at the Fuji  X-E1 High ISO.
Makes me wonder if I'll ever use the flash on it.
- Simon, Sydney
pfillion Regular Member • Posts: 103
I'm impressed!
MTI New Member • Posts: 4
EM5 is on f/1.8.
Please, could you repeat these shoots? thanks
Luke_S Regular Member • Posts: 130
And with constant WB, please.
www.epicure.pl | between the walls and pieces of plastic we breathe
Adamant Contributing Member • Posts: 745
What am I missing here?  The Oly looks much sharper at ISO 12,800.
OP MDGolfer Regular Member • Posts: 203
Re: EM5 at f1.4
man!!!!!!! EM5 at auto wb changes the way it renders images constantly. Even at incandascent, it was hit or miss!!
Anyway, here you go!
Zardoz
Zardoz Senior Member • Posts: 1,249
Hi friend,
It's not a WB problem, but a bad interaction between the shutter speed and the flicker of fluorescent lights.
THANKS.
DonSantos Senior Member • Posts: 1,145
The x-e1 and 35mm lens is quite sharp!
 DonSantos's gear list:DonSantos's gear list
Fujifilm X100S Nikon D600 Sony Alpha a7 Sigma 35mm F1.4 DG HSM Art Nikon 85mm F1.8G +3 more
boinkphoto
boinkphoto Contributing Member • Posts: 989
Well, I certainly prefer the Fuji white balance, but that's hardly an important factor given I shoot RAW (and may be specific to this photo anyway)...
 boinkphoto's gear list:boinkphoto's gear list
Fujifilm X-Pro2 Fujifilm X-E2S Fujifilm X-T2
intruder61
intruder61 Veteran Member • Posts: 3,064
the big problem you have here is the "big turn big drives"....if you dont get your hips out of the way on the downswing after a "big turn" , you are gonna get stuck-blocked and push your shots out to the right.    cheers.
hellocrowley Senior Member • Posts: 1,291
Zardoz wrote:
Hi friend,
This. Notice some photos are half white, half yellow.
