EF-S 17-55mm f/2.8 IS USM - Focal Length Confusion
Started Oct 10, 2012 | Discussions
ryllz New Member • Posts: 3
Hi All,
I am very new to DSLR photography and have just recently purchased the T4i with the 40mm 2.8 lens.  To upgrade the lens kit that came with my camera 18-55, I am contemplating purchasing the 17-55 2.8 based on all the reviews I have read here and other sites.
My question is this: If the EF-S 17-55 was specifically made for the APS-C DSLRs and is not compatible with the FF cameras then why would the equivalent focal length still be at 27-88mm on the APS-C DSLR??  This confuses me a whole lot and i've read quite a bit.  I still have not found the explanation.
Based on my question above then what type of camera should I buy to take advantage of the actual 17-55mm focal length that I am planning to buy (obviously not an APS-C and this does not work on a FF so what are my other choices??)
Please forgive this very amateur question but it confuses me to no end.
Thanks in advance for the responses.
Ryll
Canon EF-S 17-55mm f/2.8 IS USM Canon EOS Rebel T4i (EOS 650D / EOS Kiss X6i)
PC Wheeler
PC Wheeler Forum Pro • Posts: 17,902
Re: EF-S 17-55mm f/2.8 IS USM - Focal Length Confusion
Welcome to the DPR forums!  There are two separable issues above, lens mount and crop factor.
  • The APS-C cameras (all but the 10D, I believe) will use both EF and EF-s lenses. FF DSLRs can use only EF lenses.
  • The eff. focal length of a lens depends on the sensor size. For Canon APS-C DSLRs the crop factor is 1.6.  1.6x (17-55) is approx 27-88 mm. That has ​nothing​ to do with the EF vs. EF-s mount.  So if you used a 17-40L EF lens on an APS-C body the focal length would become 27-64 mm.
So you can use that lens, the very fine 17-55 f/2.8, on any Canon APS-C body (60D, 7D or one of the Rebel or xxxD series) but not on a full-frame body (6D, 5D, etc.).
Phil
 PC Wheeler's gear list:PC Wheeler's gear list
Canon PowerShot ELPH 330 HS Panasonic ZS100 Sony RX10 IV
Jasper in SF
Jasper in SF Regular Member • Posts: 341
ryllz wrote:
Hi All,
Ryll
I think that the confusion is in that the equivalence is, in part, for people whose reference is to film and full frame.  For some people moving from film to APS-C, the conversion helps them to understand the field of view.  17-55 on a crop camera (APS-C) provides the same field of view as would a 27-88 on a full frame or 35mm film camera.    If you took an image using 35mm or full frame camera and a 50mm lens, the same image (using the same lens) from an APS-C camera would look as if the full frame/film image had been cropped...equivalent to taking the same image on a full frame/35mm camera with an 88mm lens....distance form subject being constant.  Thus APS-C cameras are called crop cameras.  You have the right camera for the 17-55. It just helps some folks moving from 35mm to know that the "crop factor" is 1.6, and that a lens, for instance the 17-55, provides the equivalent that a 27-88 lens  would on a full frame/35mm camera (although no one makes that focal range, nearest is 24-70).
Enjoy the 17-55 - it is indeed an excellent lens.
Best,
'There is no un-suck filter.'
- David duChemin
Which is too bad, because I could sure use one.
http://www.flickr.com/photos/jasper_rubin/
 Jasper in SF's gear list:Jasper in SF's gear list
Canon EOS 5D Mark III Canon EF 24mm f/2.8 Canon EF 50mm F1.8 II Canon EF 17-40mm f/4.0L USM Canon TS-E 24mm f/3.5L II +3 more
mrahmo Contributing Member • Posts: 580
the focal length is really 17-55mm, but the image circle is small not for FF
so if u compare the result to the FF body u must multiply by 1.6
 mrahmo's gear list:mrahmo's gear list
Canon EOS 5D Mark III Canon EF 50mm F1.4 USM Canon EF 16-35mm F2.8L II USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-105mm f/4L IS USM
Olga Johnson Forum Pro • Posts: 24,360
ryllz wrote:
Hi All,
Ryll
Since the camera can use EF as well as EF-S lenses, imagine the confusion folks would have if the EF-S lenses were using a different focal length measurement than the EF lenses while providing the same field of view and depth of field.
Olga
asad137 Contributing Member • Posts: 693
Nobody really answered your question. Basically it comes down to why lenses are named what they are. The focal length of the lens is ​defined ​as what distance behind the lens the rays converge to a focus when the lens is focused at infinity. This measurement is independent of sensor size. Focal length is focal length, ​always​.
However, for a very long time, the dominant photographic format was 35mm film (equivalent to DSLR "full frame"), so a lot of people are used to thinking about focal lengths in terms of the field of view a given focal length provides ​on a 35mm frame​. When you have a sensor smaller (or larger!) than a 35mm frame, people talk about "effective focal length". The smaller sensor sees a smaller part of the image circle created by the lens, and so acts like a crop or zoom in on the central part of the field of view. So your 50mm lens on a full frame has the same ​field of view​ (NOT focal length!) as an 80mm lens on a 35mm frame if that same 50mm lens is used on a Canon 1.6x crop factor camera (i.e. all of their DSLRs except their full-frame models).
OP ryllz New Member • Posts: 3
All THANK YOU so much for clarifying this for me! For a while I was confused as heck.  So much to learn and have actually signed up for a 3 day Photography workshop in my area. Cant wait!
Again many thanks for the clarification!
FYI i'm planning to purchase the canon 17-55 from BH Photo today BUT was tempted with the Tamron 17-50 version due to all the rebates that Tamron is giving until Dec. 31st.  So i've resigned to reading some more comparisons and reviews before I make my decision...
Otola Regular Member • Posts: 192
I've had it (the Canon 17-55) for several years and it is indeed excellent. However, I felt the range was too limiting, it is huge, very expensive and at f2.8 it is not that sharp so I traded it for a Canon 15-85, which I find a much more practical zoom still with excellent quality. Your mileage may vary of course.
Peter Kwok
Peter Kwok Senior Member • Posts: 2,635
Your T4i is not a P&S
P&S cameras are marketed with equivalent focal length of their zoom lens.  It is a convenient way to compare with other brands.  For example, the S100 is said to have a 24-120mm zoom.  If any one actually look at the lens, it says 5.2-26mm.  But nobody cares.
1.6 crop bodies are meant to use both EF-s and EF lens.  It is easier to say your lens is 17-55mm, not because Canon think their customers are smart to do the math conversion to 27-88, but because it is easier to compare with other full frame lens.  You can know that a 50mm lens is about the same as the 17-55 zoom all the way in and a 85mm lens is a bit longer than this zoom.  If the 17-55 is marketed as a 27-88, people may think the 85mm has less reach.
Peter Kwok
Click here for my PBase gallery
WYSIWYG - If you don't like what you get, try to see differently.
 Peter Kwok's gear list:Peter Kwok's gear list
Canon EOS 5DS Canon EOS R5 Canon EF 16-35mm F4L IS USM Canon RF 14-35mm F4L IS USM Canon EOS M6 +8 more
Buchanan Senior Member • Posts: 1,124
My 17-55 is very sharp at 2.8 and throughout the stops.  From what I've read here over the years this seems to be the norm.
 Buchanan's gear list:Buchanan's gear list
Canon PowerShot S95 Canon EOS 60D Canon EOS 6D Canon EOS Rebel SL1 Canon EOS 70D +15 more
