17mm TS-E Flare reducing hood/ shade ideas allowing full shift FF?
Started Oct 8, 2012 | Questions
Quintin Lake
Quintin Lake Forum Member • Posts: 96
Hi,
I find for architectural shots at dusk, with street lights, this lens although beautiful in quality, flares very badly when point lights are in the frame like street lamps. I've spent way too long in photoshop correcting these flares in post and am looking to improvise some kind of barn doors or bellows lens hood / shade that will allow full shift with a full frame sensor. Holding a board is not sufficient if the source of flare surrounds the camera
 Quintin Lake's gear list:Quintin Lake's gear list
Canon PowerShot G1 X Canon EOS 5D Mark II Canon EOS 6D Canon EOS 5DS R Canon EF 14mm f/2.8L II USM +10 more
(unknown member) Senior Member • Posts: 2,261
Wimberly plamp or similar tools will hold & position your cards
Ben_Egbert Forum Pro • Posts: 20,228
Re: 17mm TS-E Flare reducing hood/ shade ideas allowing full shift FF?
Quintin Lake wrote:
Hi,
I have the hood and have used it on my 17tse with a home made adaptor. You can see my write up here. You can't get full shift with the hood and not even with the less obtrusive Lee foundation kit. You can get some shift with the hood. Mine has a 105mm filter thread on the front, it would allow more shift if that were removed.
If you read my stuff be aware that I abandoned the 4 inch water pipe mount for one made from a spare lens cap.
http://ben-egbert.smugmug.com/Utility/17TSE-lens-hood-adaptor/15776282_tWQXNF#!i=1855432676&k=dRdJxvq
Another link
http://ben-egbert-photo.com/?page_id=195
What I see when I open the image and view it at 100% is very important to my overall attitude toward a final print. When I look at the print I know what’s there and what I had to do to get there. For me, good enough does not work.
Ben
 Ben_Egbert's gear list:Ben_Egbert's gear list
Canon EOS 5D Mark III Canon EF 16-35mm F2.8L II USM Canon EF 70-200mm f/2.8L IS USM Canon TS-E 17mm f/4L Samyang 14mm F2.8 ED AS IF UMC +1 more
Quintin Lake
OP Quintin Lake Forum Member • Posts: 96
Re: Wimberly plamp or similar tools will hold & position your cards
Apewithacamera wrote:
http://www.tripodhead.com/images/dealer-plamp1.jpg
Thanks for the idea but I would need three for top and two sides so it would get very cumbersome and wouldn't work well in the wind
Quintin Lake
Hi Ben,
Many thanks for sharing this, looks a good solution you have made.
Regards
