Do you think Olympus 75mm F1.8 is sharp wide open?
Started Oct 6, 2012 | Discussions
micksh6
micksh6 Senior Member • Posts: 2,613
Well, at least it allows to get close. But, is it sharp enough, what do you think?
75/1.8
75/1.8
 micksh6's gear list:micksh6's gear list
Olympus PEN E-PL5 Olympus E-M1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +6 more
TheEye
TheEye Veteran Member • Posts: 4,883
Furry
On which particular hair did you focus?
micksh6
OP micksh6 Senior Member • Posts: 2,613
Re: Furry
In the first shot I focused on the eyelash.
Erik00 Regular Member • Posts: 251
Re: Do you think Olympus 75mm F1.8 is sharp wide open?
75/1.8
75/1.8
If it isn´t sharp enough for you, you might have a problem. Hope you are satisfied.
Nikko aus London Senior Member • Posts: 1,220
It's depth of field is very narrow wide open which may lead you to your conclusion.  That conclusion is, of course, incorrect.
N
 Nikko aus London's gear list:Nikko aus London's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 75mm F1.8 Olympus 8mm F1.8 Fisheye Pro Olympus 12-100mm F4.0 +1 more
micksh6
Let's forget about my problems for a moment. And, Nikko aus London, I wonder how you figured out what conclusions I made. And that my conclusions are already incorrect. This doesn't help my self-assertion as a photographer in any way.
I may have a problem being a little indecisive. Sometimes I take photos that I like but my wife hates them. My friends love some of my photos, but they won't tell a thing about another ones.
But this is not what this thread is about.
So, I asked a question to wider audience - if the photos look sharp. That's a simple question, isn't it?
TheEye
Show us a 100% crop of the area that contains the element (eyelash, you said) on that you focused. Then we can judge sharpness.
Vlad S Veteran Member • Posts: 3,766
Sharp enough to get cut
I think in the first picture it's easier to see sharpness in the eyebrow, because the hairs are better separated than in the eyelashes. It's awfully sharp, but I think I would prefer the whole face to be in focus, especially when the background is far enough to maintain isolation even at smaller apertures.
Vlad
75/1.8
75/1.8
 Vlad S's gear list:Vlad S's gear list
Olympus OM-D E-M5 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +2 more
LTZ470
LTZ470 Forum Pro • Posts: 11,926
So sharp it will cut you...
--Really there is a God...and He loves you..
FlickR Photostream:
www.flickr.com/photos/46756347@N08/
Mr Ichiro Kitao, I support the call to upgrade the FZ50.
I will not only buy one but two no questions asked...
TheEye
Re: Sharp enough to get cut
Where it's on focus it looks razor-sharp to me.
I think the 75 mm would be best for 3/4 or full body portraits, while the 45mm would be better suited for headshots.
A longer lens will include less surroundings for the same framing of the main subject, so if one wants or needs to exclude objects on the sides of the frame, then the 75 will give an advantage. But for head shots it definitely needs to be stopped down to have more of the face in focus.
Vlad
Camancha Contributing Member • Posts: 740
Yes, it's very sharp.
Kind regards
.lars
Bangers and Mash
Bangers and Mash Veteran Member • Posts: 3,010
Ditti
Kind regards
.lars
I agree!!
 Bangers and Mash's gear list:Bangers and Mash's gear list
Olympus OM-D E-M5 Olympus TG-5 Olympus PEN-F Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R +4 more
How did I figure out your conclusions, Mick?  Perhaps it's to do with how you phrased your questions: "Is it sharp wide open?" in the post title and "Is it sharp enough?" in the body of your post.  I'm no Einstein but I drew the same conclusion as other respondents which is that you have some concerns about the relative sharpness of this lens.  That's a fair assumption, no?
That being the case, and because of the experience I have in owning one, I thought I would try to assuage your angst by pointing out that, wide open, this lens has a very narrow depth of field measured in a few cm.  When shooting it wide open, one might incorrectly conclude that the lens is not sharp because areas adjacent to the critically-sharp focus point appear less sharp as a consequence of narrow DOF.
Does that clear up the matter of: (a) how I came to make the assumptions I did; and (b) how I thought I would try to help your understanding?  My style may be sparse at times but never malicious.
Nikko
Yohan Pamudji Senior Member • Posts: 2,876
Is this a trick question?
The answer seems so obviously "yes" that I feel like I'm walking into a trap
micksh6
Nope:) I just asked a question - what do people think.
Yes to both (a) and (b). Thank you. Now I understand.
Sorry for confusion. Everybody assumed that these are full shots, right?
TheEye: "Show us a 100% crop of the area that contains the element (eyelash, you said) on that you focused"
These are 1.3 and 1.6 megapixel crops.
I presented this thread in such way to illustrate how deceiving it is to judge sharpness by 1 megapixel images. And some are posting 0.5-1.3 megapixel pictures to brag about sharpness of their gear (Panasonic FZ200 owners in particular).
And, of course, I wanted to emphasize sharpness of Olympus 75mm lens. I figured if 10% crop would appear sharp then disclosing that lens renders 10 times more detail would make a stronger point.
BTW, how could you (all) not notice that these were crops?
See the second shot in OP. If it were full frame even Oly 45mm at F1.8 would show one eye sharper than another. But both eyes are almost equally sharp. This shows too wide DOF (even for m4/3).
I got you, didn't I?
Don't put me in a troll list just yet:) I am still a contributing member according to new DPR rating and I will continue to contribute. Until I become a senior, at least.
Below are the full shots. And please see my next thread with Oly 75mm samples:
http://forums.dpreview.com/forums/post/50018934
Olympus 75mm F1.8 at Renaissance Faire
micksh6
Re: Is this a trick question?
Seems like you knew it:)
"BTW, how could you (all) not notice that these were crops?"
Guess we're all blithering idiots.  At least that's how I feel.  Mission accomplished, bravo.
RonFrank
RonFrank Senior Member • Posts: 2,130
People here would argue over if the sun is hot.....
 RonFrank's gear list:RonFrank's gear list
Nikon D1X Nikon D200 Nikon D300S Sony a6000 Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR +7 more
Well, of course if you compare it with other stars, you could argue... :D (nt)
