Filters on the SX40 HS?
Started Oct 5, 2012 | Discussions
james2k50
james2k50 Contributing Member • Posts: 573
I've noticed that the diameter of the lens is 52 mm. Why can't I use a 52 mm filter and screw it in? Would this harm the lens in any way? What are my alternatives? Thanks, James
 james2k50's gear list:james2k50's gear list
Canon PowerShot SX40 HS Sony SLT-A35 Sony SLT-A65
RDCollins
RDCollins Senior Member • Posts: 1,194
Re: Filters on the SX40 HS?
There are a couple of recent threads about filters for the SX40.
Canon recommends that you use 67mm filters (my preference), although 58mm filters will also work albeit with possible vignetting (i.e., dark corners in photo at the widest angles). Either size requires a filter adapter. The filter screws into the adapter, which attaches to the lens with a bayonet mount.
A 52mm filter cannot be used with the SX40. Even if you managed to attach it to the lens somehow, I believe the metal/plastic rim of the filter would be visible in most shots.
Doug Collins
Hermosa Beach, California
 RDCollins's gear list:RDCollins's gear list
Sony a6400 Sony E 50mm F1.8 OSS Sony E 55-210mm F4.5-6.3 OSS Sony E 10-18mm F4 OSS Sony E 16-50mm F3.5-5.6 PZ OSS +2 more
Dale Buhanan Veteran Member • Posts: 4,280
Those are not screw threads on the lens barrel, they are baffle rings.  You cannot screw a filter onto them.
kind regards
Dale
 Dale Buhanan's gear list:Dale Buhanan's gear list
Canon PowerShot SX50 HS Canon G1 X II Canon EOS 70D Canon PowerShot SD500 Canon PowerShot G5 +35 more
