HVL-F43AM for Nex 6?
Started Sep 14, 2012 | Discussions
DavidB2 Regular Member • Posts: 395
Can anyone tell if the HVL-F43AM flash is compatible with the Nex 6? Sony's site only shows a single flash -- a not yet released model that is bigger & more expensive -- as compatible with the Nex 6.
I find it interesting that there are so few threads here about using a flash with the Nex cameras. What do you all do indoors?! Is no one using a flash because they are too big/awkward with the Nex bodies?
 DavidB2's gear list:DavidB2's gear list
Nikon D7200 Olympus OM-D E-M10 Fujifilm X-E1 Fujifilm X-A1 Sony Alpha a7R III +26 more
FotoMc New Member • Posts: 7
Re: HVL-F43AM for Nex 6?
I use this:
I can't say if it will work on a Nex-6 though.
Fredy Ross Veteran Member • Posts: 6,812
Yes inotice on the sony site that the new flash is compatible with the nex 6. A friend is going to photokina and hopefully they will have one to try and I asked her to report back as we are both buying the nex 6. Hopefully they will have a model there for people to try with the nex 6.
fredyr
martindesu
martindesu Senior Member • Posts: 1,247
FotoMc wrote:
I use this:
That looks gorgeous.
What flash is it?
 martindesu's gear list:martindesu's gear list
Sony RX1 Sony Alpha NEX-C3 Voigtlander 35mm F1.4 Nokton Sony FE 55mm F1.8 +1 more
martindesu wrote:
What flash is it?
HVL-F43AM
wkramer Forum Member • Posts: 67
All Sony mount flashes will need an adapter in order to use them on the Nex 6. The flash mount has been changed to a standard flash mount.
 wkramer's gear list:wkramer's gear list
Fujifilm X100S Epson Stylus Pro 3880 +5 more
OP DavidB2 Regular Member • Posts: 395
That's disappointing. How strange for Sony to change its hot shoe and then only come out with a single compatible flash -- one that costs $550. I wonder if there are/will be 3rd party flashes to fill the gap that will work well with the camera (i.e., not just on manual).
perry rhodan
perry rhodan Senior Member • Posts: 1,723
There will be a new midrange flash for the new iso shoe from sony. Expect the announcement in two weeks.
Regards P
icycool123 Regular Member • Posts: 166
Theres an adaptor for the nex 6 for use with the older flashes and it should be released soon.
Meanwhile i use an external flash with my nex 7. hvl-43
José B
José B Forum Pro • Posts: 18,388
Thanks for sharing your setup----wow, even the mid-range flash still looks huge and I don't even use legacy lenses on my NEX-6.
José
 José B's gear list:José B's gear list
Sony Alpha NEX-6 Canon EOS 5D Mark II Canon EOS-1D Mark III Sony a6000 Canon EOS 5DS +12 more
pmow
pmow Contributing Member • Posts: 825
Wouldn't the ISO hotshoe permit you to use any flash?
Is the reason an expensive Sony flash is needed because the ISO mount doesn't support TTL?
Inquiring mindsnoobs want to know.
 pmow's gear list:pmow's gear list
Fujifilm X-T1 Fujifilm X-E1 Carl Zeiss Touit 2.8/12 Fujifilm XF 35mm F1.4 R Fujifilm XF 27mm F2.8 +3 more
Jchen195
Jchen195 Forum Member • Posts: 57
Glenn Veteran Member • Posts: 7,893
is the flash head facing forwards ? it can't do HSS with the flash pointed anywhere except forward is the only thing I can think of. I checked and your camera can do HSS with that flash .. or it's supposed to anyway
Jchen195
Absolutely perfect!
I rarely shoot with the flash facing forward, but I angled the head down and the HSS icon showed up.
Thanks!
kaku Contributing Member • Posts: 681
What wireless trigger is that if I may inquire?
That is a pixel Soldier TF-373. the same ones I use.
