DIY Macro tubes (off the shelf)
Started Sep 14, 2012 | Discussions
v12nut Regular Member • Posts: 293
Hi All,
I was inspired by IHKim's tubes but not having access to a cnc machine or 3d printer, I thought I should look to see just what I could achieve with off the shelf bits, here is what I have put together so far.
Parts required
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=150888724291
http://www.ebay.com/itm/60-62-MM-60-MM-62-MM-60-to-62-Step-Up-Ring-Filter-Adapter-/320844361182?pt=US_Filter_Rings_Holders&hash=item4ab3d06dde
http://www.ebay.com/itm/55mm-Macro-Reverse-Adapter-Ring-for-Samsung-NX-NX10-NX11-NX20-free-Shipping-/270766183140?pt=US_Lens_Adapters_Mounts_Tubes&hash=item3f0aec12e4
I chose these rings because being the screw together type I would only have 1 mount at each end to fabricate. If you simply wanted a set of tubes for say a pentax k mount to NX then just glue the nx macro ring to the stepup ring, then with the rest of the above you are good to go by just assembling the parts as in this pic
Or you could adapt a NX lens cap as here
This would give you a set of 'dumb' tubes with NX mounts at each end.
It would also be possible to use just the front and rear mounts that you have made on bellows!
But as with all projects there is always the 'what if factor' so as it is only 2 ends/mounts that have to be worked on, I am now trying to figure out how to make 'smart' nx tubes from these parts, a few Ideas sofar............
This wont be an elegant solution I know but I figure for probably a total outlay of $20 who cares as long as it works!
However if any of you clever chaps out there have any bright ideas! please let me have your comments asap!
Cheers
Tom
hootsmon
hootsmon Contributing Member • Posts: 903
Re: DIY Macro tubes (off the shelf)
Brilliant! Thanks that looks good.
 hootsmon's gear list:hootsmon's gear list
Samsung NX11 Samsung NX30 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 85mm F1.4 ED SSA +1 more
OP v12nut Regular Member • Posts: 293
Thanks.
I have figured out the 'lens ' end contacts (pogo pins) would really appreciate some ides for the 'camera' connector contacts!
Cheers
nx200USER1 Senior Member • Posts: 1,097
Sorry I cannot contribute to your thread in a technical sense, however I fully support your endevours, being inspired with this kind of ingenuity. Always good to see the grey matter pursuing alternative avenues
great work so far!
This is the final version of my DIY tubes, found these nice contacts at Mouser, still not pretty but they work,
This also works with my bellows set.
A couple of really quick hand held pics
Here's a few with the tubes and 30mm
hootsmon
Mate, this is awesome!  Well done.
Thanks, as I said they aint pretty but it does work well.
Cheers
