Samyang 24 TS = pressure for a Nikon 24 PC-E upgrade?
Started Sep 7, 2012 | Discussions
lovEU Veteran Member • Posts: 3,134
From their press release I'm not sure if the now announced Samyang lens will enable independent tilt and shift axis rotation. But if so that's a nice advantage over the much pricier Nikon lens.
http://www.dpreview.com/news/2012/09/07/samyang-24mm-f3-5-tilt-shift-lens
Tilt-Shift function
Tilt-Shift function in Samyang T-S 24mm 1:3.5 ED AS UMC allows for smooth and individual adjustment of the focus plane angle by + -8.5 and enables parallel shift of the optical axis by + -12 millimeters. To make Tilt-Shift function even more seamless, both the lens mount as well as Tilt-Shift section may be rotated on the optical axis. The Tilt-Shift section may be rotated left by 90 degrees (with 30 degree adjustment), while mount of the lens may be rotated both in left and right direction by 90 degrees, also with 30 degree adjustment.
regards, eric
Robin Casady Forum Pro • Posts: 12,898
Re: Samyang 24 TS = pressure for a Nikon 24 PC-E upgrade?
Looks interesting. My reading of the dpreview and Nikon Rumors info is that, yes, there will be rotation between the tilt mechanism and the shift. So much superior to the Nikon PC-E mechanism.
I wonder what it will cost, whether it will have a Nikon chip, and when it will be available in the USA. I have their Rokinon (USA brand for Samyang) 85mm f/1.4 and it is a very good lens, especially for $325. Very sharp and contrasty on a D800E.
Robin Casady
http://www.robincasady.com/Photo/index.html
Bobby Handal
Bobby Handal Veteran Member • Posts: 5,575
yes, I am hoping it has the chip or cpu . Love the close focus ability. Looking good !
 Bobby Handal's gear list:Bobby Handal's gear list
Panasonic Lumix DMC-TS3 Sony Cyber-shot DSC-HX400V Nikon Coolpix AW130 Nikon Coolpix P900 Olympus TG-5 +75 more
WIMorrison Senior Member • Posts: 1,844
What use would any chip be? The nature of this type of lens is that it is totally manual therefore nothing to be gained, or none that I can see.
 WIMorrison's gear list:WIMorrison's gear list
Nikon D7000 Nikon D800E Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF-S DX Nikkor 10-24mm f/3-5-4.5G ED Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR +13 more
1. It would identify the lens in the EXIF data.
2. Would save you the effort of remembering to identify it in the non-CPU menu.
3. Matrix metering uses the information from the lens. Not sure if this would work, because focus would probably not have an electrical connection through the tilt/shift mechanisms. Still, #1 & 2 would make it worthwhile for me.
Robin Casady
Thanatham Piriyakarnjanakul
Thanatham Piriyakarnjanakul Contributing Member • Posts: 636
82mm filter size as same as Canon.
All PC-e is 77mm filter size, if Nikon updated it I think there is no 77mm filter anymore.
http://www.flickr.com/photos/thanatham/4999386176/
I'm photographer from Thailand and English not my primary, sorry.
 Thanatham Piriyakarnjanakul's gear list:Thanatham Piriyakarnjanakul's gear list
Nikon 1 V1 Nikon AF-S Nikkor 200mm f/2G ED-IF VR Nikon 1 Nikkor VR 10-30mm f/3.5-5.6 Nikon 1 Nikkor VR 30-110mm f/3.8-5.6 Nikon 1 Nikkor 18.5mm f/1.8 +1 more
You may be lucky then as this picture shows CPU contacts and that would tend to indicate that they serve some purpose as they would be too expensive to put in just for looks
http://nikondslrtips.com/samyang-24mm-tilt-shift/
I would be able to work out that this lens took the picture just by looking at the picture
pixel_peeper Regular Member • Posts: 178
The picture is a fake.
mikemsphoto Senior Member • Posts: 1,803
Re: Samyang 24 TS Fake photo
Maybe they are making a 24 tilt shift but the linked photo looks fake to me. Looks like a mash up of Nikons 14-24 front element grafted onto Nikons 24 PC-E.
Knobs etc including the opposed shift vs tilt controls is identical to Nikon.
Zoom in on the Samyang nameplate on the lensmount side...pretty bad Photoshop job.
Michael Sherman
http://www.msphoto.ca
freddyNZ Senior Member • Posts: 2,611
There's no "maybe" about it. They are making a 24mm TS.
One slight inconvenience is that it will almost certainly not have an automatic aperture.
just Tony
just Tony Senior Member • Posts: 2,206
What's your opinion of the photos where they are aligned?
Speaking personally, I'm not good enough in PS to get that image starting from this one:
http://www.nikonusa.com/Nikon-Products/Product/Camera-Lenses/2168/PC-E-NIKKOR-24mm-f%252F3.5D-ED.html
It's definitely the image of the PC-E 24 from the Nikon site from the lens mount until just to the left of the aperture ring. (lthey deleted the rubber ring to adjust aperture) then the left half of the lens is a photo of the Samyang 14mm 2.8.
Michael Sherman
That fake picture has been around for months. The real thing is here:
http://www.samyang.pl/index.php/en/2012/wrzesie
Photokina Announcement?
I thought I read that the official announcement would be today (18th) at Photokina, but I can't find any news for it. I'm most curious about the price.
Anyone seen anything?
Robin Casady
VividExposures Contributing Member • Posts: 989
Re: Photokina Announcement?
I am very curious about the price as well. Their website says the 18th. Keeping my fingers crossed that it is affordable.
