T4i Burst Mode Weirdness
Started Sep 3, 2012 | Discussions
englishman
englishman Senior Member • Posts: 1,018
Just recently my new t4i was taking tons of shots (jpg) in burst mode without a hitch. All of a sudden today it would take three shots, then pause, then take two more, then pause, etc., and it was doing this very consistently. I thought maybe it was because I had turned on highlight tone priority, so I turned that off. But that didn't make a difference. I tried taking the battery out to reset it, but that didn't seem to make a difference either. I tried using different modes, but still the burst mode was working very erratically. Any ideas on what could be causing this?
 englishman's gear list:englishman's gear list
Sony a7 III Sony FE 55mm F1.8 Sony FE 24-105mm F4 Apple iPhone 12 Pro Max
Canon EOS Rebel T4i (EOS 650D / EOS Kiss X6i)
BAK Forum Pro • Posts: 26,020
Sounds to me...
If the camera would take lots and lots of shots in a row, it was not set on RAW.
Now that it only takes a few shots,and then pauses to "catch its breath" I'm betting it is set on RAW or, more likely, RAW + JPEG.
BAK
DSHAPK Contributing Member • Posts: 782
Re: Sounds to me...
I agree with this. There is also a small possibility the card is problematic, but most likely the camera is set to raw or raw plus jpg.
 DSHAPK's gear list:DSHAPK's gear list
Canon EOS 550D Canon EOS Rebel T4i Canon EF 50mm F1.4 USM Canon EF-S 10-22mm F3.5-4.5 USM Canon EF 55-200mm f/4.5-5.6 II USM +3 more
englishman
OP englishman Senior Member • Posts: 1,018
Re: Sounds to me...
Thanks guys for your responses. I also thought this as I shoot RAW in different situations, however, I checked this right away and the camera is still only set to JPG. So that rules that out.
englishman
Re: Sounds to me...
A little more information. I tried a different memory card--didn't fix it. I tried a different lens--didn't fix it. I tried clearing ALL camera settings (back to factory default)--still didn't fix it. How annoying! I've already had to return one of these. I really don't want to return another. Burst mode is simply only doing three shots now. BAM-BAM-BAM -- fast! Then slow. BAM------------BAM------------BAM, etc. Same thing every time. What gives? I was LOTS of fast shots in a row earlier. Getting my kid running at me, etc. Now I get three . . . then it pretty much goes useless.
jon lake
jon lake Senior Member • Posts: 1,632
Re: Sounds to me...
Have you got noise reduction switched on? This will do it as well as highlight tone priority or whatever it's called.
Jon
 jon lake's gear list:jon lake's gear list
Canon PowerShot G12 Canon EOS-1Ds Mark II Canon EOS-1Ds Mark III Canon EOS 40D Canon EF 85mm F1.8 USM +3 more
Lemming51
Lemming51 Forum Pro • Posts: 15,278
High ISO NR is the culprit, not HTP.
p. 124 of the instruction manual. Resetting to factory defaults enables High ISO NR. Turn it off to restore maximum burst capability.
Highlight Tone Priority on/off has no effect on burst rate.
Edit:
p. 323 gives other causes of lower burst rate:
  • setting ISO to 12800 or H
  • Chromatic Aberration correction: Enabled
  • WB Bracketing enabled
Jon
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
logs90 Regular Member • Posts: 308
Re: Sounds to me...
Your memory card should have a rating of at least 6 for faster write speed.
photonius Veteran Member • Posts: 6,895
Re: T4i Burst Mode Weirdness
Maybe two separate things causing it?
I.e. on the hand maybe one of the settings (even after reset) as suggested by other posters.
But in the first instance of the slow-down, perhaps you card was getting full? Does anybody know how SD cards react to memory fragmentation, does it occur?
Life is short, time to zoom in ©
 photonius's gear list:photonius's gear list
Canon EF 100-400mm F4.5-5.6L IS II
englishman
Re: High ISO NR is the culprit, not HTP.
Edit:
Lemming and Jon, you guys got it. High ISO noise reduction. At gymnastics the other day I was shooting at ISO 1600 and I turned the NR to high to test out the results. I forgot to turn it off because I don't usually shoot at high ISOs.
After I reset the camera to defaults last night the NR was set to standard but I was still having the problem. Why? Because I was in my low-light office and was shooting at ISO 12800 to get a decent shutter speed!
Phew! Thank you!
jon lake
Glad it's sorted. I've done the same!
Good to know for future reference!
kb9nvh New Member • Posts: 3
Edit:
Phew! Thank you!
Lens aberration correction also caused my jpegs bursts to stop at 2 or 3,  Raw I can get up to 7 shots.  Now jpegs on large can go all day...
