Overide Developer settings
Started Sep 1, 2012 | Discussions
hpchan
hpchan Contributing Member • Posts: 648
First time change Adjustment Control/Line process step =25 and Line process mark=24:
size of jpg seems increased.
hpchan
 hpchan's gear list:hpchan's gear list
Samsung NX100
nx200USER1 Senior Member • Posts: 1,097
Re: Overide Developer settings
gonna give that a try on my nx200.
Ariston Senior Member • Posts: 2,401
what does it do?
paulhome Contributing Member • Posts: 841
Ariston wrote:
what does it do?
 paulhome's gear list:paulhome's gear list
Fujifilm X-E1
nevada5
nevada5 Forum Pro • Posts: 12,910
Sounds good......
But what are you talking about?
Larry
http://www.pbase.com/fernley
I'm experimenting with Quantum Physics and I just discovered that I can completely destr
 nevada5's gear list:nevada5's gear list
Sony RX100 II Canon PowerShot S120 Panasonic Lumix DMC-GF2 Panasonic Lumix DMC-GX85 Panasonic Lumix G Vario 14-42mm F3.5-5.6 II ASPH Mega OIS +4 more
hpchan
OP hpchan Contributing Member • Posts: 648
We are reopen some setting on NX200 developer menu which is off on default.
The testing is depended on NX100 development menu which has more stable jpg engine.
On NX100, Adjustment Control/Line process Step = 13, Line Process Mark =12.
Compare to NX200, Line process step=off, Line process mark=7. What is the difference when NX200 change to the same as NX100 or even higher; ie the highest setting=99?
Any improvement is what I wish to know. The testing still continue; some test on ISO
10,000 have better detail, more clean high light areas when LPS=25 LPM=24
Report at later time.
hpchan
Samsung NX100
hpchan
100% crops.
hpchan
Samsung NX100
If you are bothered about minor detail shoot raw. do you know what the settings are actually changing ?.
Fujifilm X-E1
hpchan
It is not a little change. Like other NX200 user, I am very much disappointed when using jpgs over 3200. Until one day; I discover that some leak caused by reflection of sensor frame. The dark gray sensor if tanned with pure black color, my NX200 can be good at iso 5000 (JPG). ISO 10,000-12800 only 0 EV area can use, under exposed covered with noise. My camera had locked for not go further to 3200. Further explore for anything better with these under priced NX100 and Nx200 that only had Mfr fault.
hpchan
Samsung NX100
hpchan
Hi all,
NX camera would have an additional tool, the setting above would changed linear amplifier of sensor. When setting at 25% (I use percent instead of marks) result in better details of shadow as picture 1. When set to 99, very bright image can be obtained. Sample 2 shoot at ISO 12800.
hpchan
Samsung NX100
here's the question, what control/line process step is for? and process step mark is for?
hpchan
The answer is simple after a try with your NX.
hpchan
Samsung NX100
thank you for directly answering my question.
fmwtw New Member • Posts: 1
Can you tell me where is the sensor frame and how to tan it black? I would like to improve my NX200 but I am not sure where is sensor frame and how to do so. Thank you!
hpchan
fmwts,
For more details follow this thread... forum.nxcsc.com/showthread.php?tid=97.
hpchan
Samsung NX100
hpchan
INDOOR LPS/LPM=83/82
hpchan
Samsung NX100
dlacoutu Contributing Member • Posts: 811
Could you provide a before/after comparison?
Because I don't really understand what is the effect on the pics you provided...
Edit : I've tried different combinations, and every file seems the same to me...
 dlacoutu's gear list:dlacoutu's gear list
Samsung NX100 Pentax K-5 Samsung NX200 Pentax smc FA 50mm F1.4 Samsung NX 30mm F2 Pancake +6 more
hpchan
Try only once by setting at LPM=99, 1/15 second f2.8 at candle light or one blub street on manual focus iso 12800. It will self explain the result is many time even better than LIVEVIEW. NX I have rarely seen final image better than Amoled Liveview before.
Note to select a lens with less flare.
hpchan
Samsung NX100
simontramper
simontramper Senior Member • Posts: 2,380
Do these changes have any effect if you shot RAW and do you know what happens if you turn the Line Step on and select a high number .
 simontramper's gear list:simontramper's gear list
Samsung NX200 Samsung Galaxy NX Samsung NX1 Samsung NX 20-50mm F3.5-5.6 ED Samyang 8mm F3.5 Aspherical IF MC Fisheye +10 more
hpchan
Test only OOC jpg, no raw. But lens and sensor frame have black treatments. I much consider that the image become grey if no such treatment. Dark black color is hardly obtained at high ISO 12800. More photos at 81/80.
hpchan
Samsung NX100
