"The Guard" showed up today, tamed the %@#$@ video button
Started Aug 31, 2012 | Discussions
HeavyDuty Senior Member • Posts: 2,298
I received a package today from Rick Luther containing one of his "The Guard" widgets for the NEX7. It took all of five minutes to install - it's a custom made metal grommet that mounts in the video button hole of the rubber cover. You gently peel back the cover, press the grommet in to the hole in the rubber cover and press the cover back down.
Very simple and very ingenious. I need to use a pen cap or a key to press the video button now, people with smaller fingers or fingernails can probably do it without tools. I never use video mode on my NEX7, so this is totally acceptable to me.
I like it! Well worth the $20 to me.
I'm not sure if links are allowed, so simply Google "The Guard Luther NEX7" for his website. (I have no financial interest in this, I'm just a very satisfied customer.)
Ken in Illinois
http://www.pbase.com/kjford
 HeavyDuty's gear list:HeavyDuty's gear list
Leica APO-Summicron-M 75mm f/2 ASPH Fujifilm X100S Canon XC10 Sigma dp0 Quattro Sony RX10 III +77 more
Sony Alpha NEX-7
relate2 Contributing Member • Posts: 930
Re: "The Guard" showed up today, tamed the %@#$@ video button
How do you peel back the rubber grip without destroying it? I thought it was glued on.
http://www.youtube.com/user/relate2
OP HeavyDuty Senior Member • Posts: 2,298
Nope, not glued - taped using a reusable mounting tape. If you don't touch the tape with oily or dirty fingers it stays tacky. The tape stays on the body, the rubber peels right up.
Mine is as secure now as it was before.
Ken in Illinois
dssdmd Regular Member • Posts: 199
Re: "Better address to web site
http://www.rluther.com/ or 800-345-1107
Tom Paull
Tom Paull Regular Member • Posts: 327
Received mine today, great design and it works.
THANKS Best 20.00 I ever spent on a camera and get great results.
Tom
 Tom Paull's gear list:Tom Paull's gear list
Sony RX100 Sony a6000 Sony a6300 Sony E 50mm F1.8 OSS Sony E 10-18mm F4 OSS +4 more
Tom Paull
Gentley pull back and you will notice a small tab (left top corner) when you reinstall gently push the tab back into the slot. Perfect fit and looks like you never touched it. Now NO MORE UNWANTED VIDEO"S.
gkstar Contributing Member • Posts: 569
Sounds geat... though can you take videos when you want them without having to use a tool to press the button?
 gkstar's gear list:gkstar's gear list
Sony a6400 Sony E 10-18mm F4 OSS Sony E 16-55mm F2.8 G Sony E 70-350mm F4.5-6.3 G OSS Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA +3 more
wmson2000 Junior Member • Posts: 41
Sorry if this has been asked before - anyone know if this will work on a 5n? I hate the video button placement!
Ricardo77 Forum Member • Posts: 52
Yes, you can take movies when you want. Just press the button more intentionally.
Many photographers of all shapes & sizes were part of a "beta" testing program.
The present "Guard" is the 4th prototype. Try it, you'll like it. It's very shiny!! RL
 Ricardo77's gear list:Ricardo77's gear list
Sony FE 24-240mm F3.5-6.3 OSS
Spunky8 Senior Member • Posts: 1,023
Can the guard be removed without harming the body or leaving an undesirable residue?
 Spunky8's gear list:Spunky8's gear list
Sony RX1R II Zeiss ZX1 Sony a7R III Hasselblad X1D II 50C Sony FE 35mm F2.8 +4 more
I don't see any reason why not - no modifications are made, it's sized to precisely fit the hole in the rubber.
Ken in Illinois
I'll have to try pressing with the "meat" of my thumb - I couldn't find a good way of doing it, but I didn't spend a lot of time trying either.
Ken in Illinois
The rubber grip/cover section that needs to be peeled in order to install the ring - is it the same section that people have complained would come off on its own after some use?
See "Instructions" at "Guard" site. I think some people have had an issue with
the rubber cover at the front of Nex. I can't imagine having an issue with rear rubber covering because of the two "tabs". Hope this helps. rl
That makes sense. Any idea if they would free-ship to Canada? I can find out I guess.
zackiedawg
zackiedawg Forum Pro • Posts: 34,339
Sorry - but no - there's no rubber grip to peel back and stick this under on the NEX-5N. NEX-5N users have to involve some glue or other trick to stick something over the video button.
 zackiedawg's gear list:zackiedawg's gear list
Sony a6600 Sony FE 100-400mm F4.5-5.6 Sony FE 200-600 F5.6-6.3 Sony E 18-55mm F3.5-5.6 OSS Sony E 16mm F2.8 Pancake +21 more
Yep! We have shipped several "Guards" to you guys up there.
Thanks for asking! RL
Jack West Senior Member • Posts: 1,144
you guys with the 7 got an elegant fix - i'd sure pay $20 for a clean fix [no glue] for my 5n. i guess it's impossible to get a firmware fix like 2 clicks to activate? - oh well
Jim Funston Senior Member • Posts: 1,698
Thanks for the post.... I just ordered one myself.
The entire NEX7 community owes Rick a big thank you - because now that he's developed this great solution, Sony will undoubtedly come out with a firmware update that allows you to disable the video button. It's the way of the world...
Ken in Illinois
