Magnesium alloy body? Weather sealing? Water and dust resistant? ...
Started Aug 26, 2012 | Discussions
omne Forum Member • Posts: 87
So, how important is all these? magnesium alloy body? weather sealing? water and dust resistant? ...
The 7D is all magnesium alloy but in D7000 only top and the rear of the camera is magnesium alloy, do you think that it's an important factor in choosing between these two?
Also I read somewhere that because of the heavy weight of lenses, usually the lens mount is more at risk than other parts... is that true?
I was comparing Canon 7D and Nikon D7000 and I noticed DPreview has mentioned "Water and Dust resistant" for D7 but for D7000 it says "Weather and dust resistant"... do they also have different weather sealing?
Canon EOS 7D Nikon D7000
Deleted1929 Forum Pro • Posts: 13,050
Re: Magnesium alloy body? Weather sealing? Water and dust resistant? ...
In relation to sealing and strength I'd be surprised if there was much practical difference between the two in these terms.
When using a tripod with heavy lenses you'd normally mount the lens on the tripod ( using a collar ). The camera is supported by the lens in this situation. This allows the system to be better balanced. Mounting the camera on the tripod with a heavy lens attached would result in a system likely to tip forward and basically unstable in this sense, quite the opposite of what you want from a tripod.
StephenG
OP omne Forum Member • Posts: 87
Actually one of the main reasons that I preferred the 7D over D7000 is its all magnesium alloy body, I thought perhaps it would last longer for me, but now I'm considering the D7000 again... I'm not sure when and where the magnesium alloy body really comes in use...
Alphoid Veteran Member • Posts: 5,687
What are you using the camera for?
  • If you're a wedding photographer, you can expect to have drinks spilled on it, shoot in the rain, etc.
  • If you're a photojournalist, you can expect to shoot in warzones, or at least, in big crowds of people shoving, rain or shine.
  • If you're a National Geographic photographer, you can expect the camera to get beat up a bit as you hike across Antarctica and shoot in the snow.
If you're like me, you'd prefer pro-level features with amateur-level weight. Minolta 7000 was more-or-less ideal in this regards. Even with fairly heavy amateur use, none of the dSLRs are all that likely to fail mechanically.
ARShutterbug
ARShutterbug Veteran Member • Posts: 8,993
Very important
There are all very important. Plastic bodies aren't as durable, because they're not made like Pelican cases. DW-R can save the camera and your job. The lens mount is always at risk, regardless of the weight of the lens, if the camera is dropped or somebody steps on it. If you really want weather-resistance, you should be looking at the Canon 1D and a DW-R lens.
Kris in CT
Kris in CT Veteran Member • Posts: 3,355
Very important - I Agree 100%
I have a D300 and got my first eagle shot yesterday. As I spun around my foot got caught on a root and I took a tumble. The D300 bounced hard, but survived, the verdict is out on my lens until I can shoot it some more tomorrow. My friend slipped 2 weeks ago with his 5Dm3 and it did not have a good outcome. To me the tougher the better especially if you shoot wildlife...
 Kris in CT's gear list:Kris in CT's gear list
Nikon D4 Nikon D810 Nikon D500 Nikon AF-S Nikkor 500mm f/4G ED VR Nikon AF-S Nikkor 300mm f/2.8G ED-IF VR +3 more
Re: Very important - I Agree 100%
I always caution people about generalizing based on a handful of incidents.
It looks from the image as if the 5D3's mount was the worst damaged part of the camera. That could just as easily have happened the D300. It's pure luck.
Personally I've had all sorts of objects ( not just cameras ) drop onto hard and rough surfaces and which one's survive and which one's are broken just doesn't correlate well with the notional toughness of the objects. It seems to depend on the particular details of the falls, impacts, etc. and not as much on the objects.
StephenG
Heie2 Contributing Member • Posts: 515
If you are looking for top-notch build quality and a much better IQ than the 7D, I recommend the Pentax K-5. It's significantly smaller, and features an entire mag-alloy body (vs D7000's partial).
See the video in my signature for a weather and dust sealing demonstration.
-Heie
Need affordable weather sealing in a DSLR you can trust?
http://www.youtube.com/watch?v=Eo61t5fH6Qw&feature=player_embedded
Take a look at my deployment to Afghanistan:
pentaxforums.com/forums/general-talk/196667-update-number-eleven-my-afghan-deployment-new-post.html
(you will have to copy and paste that into your browser's address bar)
Gary_Scotland
Gary_Scotland Senior Member • Posts: 1,080
Hello,
I always find that 'importance' is very subjective, so quite difficult to answer your questions. However, I will add my thoughts from my perspective
A magnesium body in general is going to offer more protection against bumps and knocks than a plastic. It isn't necessarily going to be better weather sealed, although in general I suspect that as mag bodies are going to be in the more expensive range, they are going to have a good build quality.
Weather sealing is definitely a good thing, but remember that it is not difficult to create it with a tiny budget - a clear plastic bag will pretty much guarantee you 100% weatherproofing !! Although I have said it light-heartedly, there are certainly some conditions that I would never really trust a camera's weather-proofing alone. The weak spot for water ingress is often the lens, and around the camera/lens mount, so some sort of full plastic cover isn't a bad idea if you like to shoot in wet conditions. Remember too that a 'weatherproofed' camera doesn't mean that it is waterproof
Your question about heavy lenses and damaging the mount. It really all depends on how the camera is carried/mounted/etc. For example, if you hold the camera by it's body and it has a 3Kg+ lens on the front, then there is going to be a significant stress going through the lens mount. Hold it by the lens and things are drastically changed. I wouldn't say there should be any problems using heavy lenses as long as you just think through where you need to support them. So, whether the mount is at more risk than any other camera part will really depend on the user
Gary
I don't think anyone mentioned that having a sealed body is pointless if the lens is not also sealed to the standard you require.
I'm also not sure if anyone mentioned that a dirt cheap rain sleeve can be as effective as any water sealing.
StephenG
I personally don't trust rain sleeves. They are cumbersome, can tear easily, unsightly (for the vain ones among us), and aren't necessarily reliable unless you never plan to move your camera (i.e. fixed on a tripod the entire time). Water can get under the plastic and now the sleeve is moot, either by tilting the camera up/down, or drops curling around the edge of the plastic sleeve due to its adhesive properties. Also, it could cause high humidity build up between the lens and the plastic (under the plastic) that could cause your lens to be coated in drops as well.
I personally only trust lens/camera bodies that are sealed, and Pentax just happened to have the largest variety (from 16mm-300mm), cheapest, and most compact selection of sealed lenses for APS-C
People may claim Nikon does because a lot of their Nikkor lenses contain gaskets on the lens mount - the presence of a gasket/o-ring does NOT necessarily mean it is an entirely sealed lens - refer to the manufacturer's manual for exact specifications.
For some examples, check this thread out, specifically posts 4 and 5 http://forums.dpreview.com/forums/readflat.asp?forum=1036&message=42338261
-Heie
bugzie
bugzie Senior Member • Posts: 1,614
I bought a D200 some years ago now. I must admit, I consider the build quality not so important now as the camera is most likely going to last way beyond its use-by date. Cameras don't need to last 20-odd years because the technology dates.
You can't throw it around or not worry about rain because it's always got a lens attached when you're using it and the weakest link is that lens. The camera would survive a significant fall, I'm sure. The lens most likely wouldn't.
I wouldn't make the build quality my main criteria for a camera. I like the heft and solidity of my old D200 but, practically, it doesn't really make that much of a difference. I think the all-magnesium body and weather proofing is more a selling point: it appeals to certain people even though it doesn't make any practical difference. In the field, amateurs, well, we're simply not going to take any big risks with our gear.
photosen Veteran Member • Posts: 6,226
Magnesium body alloy vs plastic: Until I see a statistical study that shows the durability of different cameras, it's all about bragging rights. I'm not considering the D7000 but I am consdering the 60D which I suppose has even less metal but feels plenty solid for my needs. Canon 300D users could give us some idea.
Weather sealing: If I lived in a place like the UK this would at the top of my list, with WR lenses of course. More weight to Pentax and Olympus in my decision (unless you've got the money for a Canon 1D series).
Water and dust resistant is sure to be important.
 photosen's gear list:photosen's gear list
Canon EOS 30D Canon EOS 70D Canon EF 35mm F2.0 Canon EF 50mm F1.4 USM Canon EF-S 10-22mm F3.5-4.5 USM +3 more
It's not so much about where you live (pero hay mucha lluvia en Mexico tambien ) but
  • Do you travel?
  • Do you want to take advantage of the few rain days you get?
  • Little rain usually means a lot of dust - protect from that as well
  • Overall piece of mind
Honestly, I'd recommend against the 60D and upgrade to the Pentax K-30. The IQ will be SIGNIFICANTLY better, AND, you will gain another control wheel (the K-30 has a front and rear, the 60D only has the rear). And the K-30 is even cheaper
Also MUCH smaller and more compact - take a look at this: http://camerasize.com/compare/#100,327
Canon EOS 60D is 12% (16 mm) wider and 10% (9.3 mm) taller than Pentax K-30.
Canon EOS 60D is 10% (7.1 mm) thicker than Pentax K-30.
Canon EOS 60D [755 g] weights 16% (105 grams) more than Pentax K-30 [650 g] ( inc. batteries and memory card).
Honestly the only thing I can see the 60D has over the K-30 is the articulating screen, which I don't know how important that is to you.
Yes I know you have some Canon lenses because you currently have invested in that system, but I honestly would sell it to switch systems - Canon used lenses command high prices and you would get so much more bang for your buck with Pentax.
-Heie
T3 Forum Pro • Posts: 21,546
Not really that important
A lot of this stuff is marketing. Plastic-bodied DSLRs can withstand far more abuse than people realize.
If you've ever wondered just how much abuse today's modern plastic camera bodies can withstand, I suggest you watch this video where they put a plastic Nikon D90 and Canon 550D through a series of torture tests to demonstrate what these camera bodies can handle. This includes...
...pouring a full cup of hot tea on each camera...twice!
...tying them to the bottom of shoes and walking around with them:
...hammering nails with them:
...kicking a soccer ball at them while they are mounted on a tripod so they come crashing onto the concrete below:
...taking a blow torch to them:
...dropping a PC on them:
And after all this abuse, the cameras survived, and the testers take these cameras out for a photo shoot...on a rainy day, no less!
And keep in mind that these are cheaper, lower level bodies using a cheaper grade of plastic and lower level of build quality!
See video here:
http://www.youtube.com/watch?v=FWzsXeXCwuc&feature=player_embedded
So suffice it to say, people greatly underestimate what these cameras can handle.
 T3's gear list:T3's gear list
Canon EOS 60D Olympus PEN E-PL3 Canon EOS M Fujifilm X-E1 Sony a6000 +17 more
lenses mount to plastic subframes
Not true.
What many people don't realize is that the lens mount of most of these magnesium camera bodies actually mount onto plastic subframes made of stiff engineering plastic!
When people look at the lens mount of magnesium alloy bodies like the Canon 10D-50D, 7D, 5D, 5D MKII, or 5D MKIII, they assume that the lens mount is attached directly to the magnesium alloy body. But if you remove the shiny metal lens mount, you'll find that it actually attaches to a subframe made of stiff engineering plastic, as you can see below:
It's this subframe of engineering plastic that is really keeping everything in place. The lens mount attaches to this plastic substructure. The tripod mounting socket attaches directly to this plastic substructure. The surrounding magnesium shell is mainly there for show: cosmetics, feel, and marketing. Also, many people also may not realize that the bottom plate of Canon's magnesium 10D-50D, 7D, and 5D-5D MKIII bodies are also plastic. If you have any of these bodies, just turn them over, tap on the bottom plate, and you'll see for yourself.
And of course, Nikon uses a plastic subframe too, just like Nikon does. This is also true of the Nikon D7000, which has magnesium cosmetic top and back plates but has plastic everwhere else.
The reality is that whether you're using a plastic-body DSLR or a magnesium-body DSLR, you're not going to see much of any practical difference in their capacity to carry a lens and keep it in place. Over the course of years, I've owned the Canon Rebel XT, 10D, 20D, 40D, 5D, and 60D. They all support lenses just fine, even heavy ones. And the really big lenses have tripod collars to support their weight. I currently own the 40D, 5D, and 60D, and when I mount my 100-400L IS on any of these bodies, they all support the lens just fine. No difference.
It's only the high-priced bodies like Canon's 1-series or the Nikon D800 that have subframes that are magnesium. Just don't expect that you're getting the same thing with lower-priced magnesium bodies.
Ian Stuart Forsyth
Ian Stuart Forsyth Veteran Member • Posts: 4,145
The majority of my damaged camera bodies are not due to the shell of the camera failing or weather sealing, it’s the 5 cent gear or 10 cent electrical component failing that’s costs $300 in labour to fix. I would look first at the shutter life and other performance before deciding the camera for your needs. I have used several pentax bodies 1 ist ds (plastic & no weather seals), 2 K10d’s, 1 K20d , 1 K7 and 2 K5’s and out of all these bodies the only 2 have not given any grief the ist ds and the k7 all the others are either weather sealed with plastic bodies or metal bodies with WS and have had problems with the components inside failing. If a camera boasts a decent shutter life and the previous generations have lived up to those numbers that’s what I would base my decision on more than what the camera is wrapped in.
The Camera is only a tool, photography is deciding how to use it.
 Ian Stuart Forsyth's gear list:Ian Stuart Forsyth's gear list
Nikon PC-E Nikkor 45mm f/2.8D ED Pentax *ist DS Pentax K10D Pentax K20D Pentax K-7 +27 more
Es diferente mucha lluvia y lluvia todo el tiempo!
(One thing's a lot of rain and another rain all the time!)
  • Do you travel?
-Heie
