EX2F availability now September 12, 2012
Started Aug 17, 2012 | Discussions
The Jacal
The Jacal Senior Member • Posts: 1,273
Re: More of the same from The Jacal
Billx08 wrote:
The Jacal wrote:
Oh, and I've been learning English since the early seventies.
Yes, and Frederick Forsythe's books probably were very helpful. I've read a couple (not including TDotJ) and think that he's overrated, almost a hack of a writer of suspense novels. But they were is more recent novels, so perhaps he became bored as he aged.
As opposed to becoming 'boring'.
I supplied the "cause". You supplied the implied "effect". This demonstrates that you sometimes do have a clue.
Very witty.
The samples are suspect, and whether you are able to understand that or not is your problem, not ours.
'Might' be my problem or is 'probably' my problem? See above.
Both are correct. English is like that, you know.
Yes I do know, and you are wrong.
But here you've lost the plot and it's back to 'no clue' for you.
Yes I do know English is like that and you are wrong about 'might' and 'probably'.
In your case though, you probably don't.
Why shouldn't I.
Putting the context back makes it easier to see :
Both are correct. English is like that, you know. In your case though, you probably don't.
Why shouldn't I.
This shows that you're convinced that not fully understanding the English language is somehow a virtue. It's understandable as an excuse, but not anything to be proud of.
Still didn't answer my question. And coming from someone who thinks that 'might' and 'probably' mean the same thing, your belief that I don't fully understand English is laughable.
Some of DPR's NX Studio Sample photos contained in their NX review were also suspect and I said so at the time that they were initially posted. DPR first denied that, giving all sorts of reasons why they were perfectly fine when the samples showed that the NX200 produced some really awful images. DPR eventually capitulated and re-shot the samples using a 60mm NX lens instead of the manual focus Pentax 50mm lens that was originally used. The new NX sample photos were vastly superior, with DPR admitting that they produced higher resolution than the NEX7's images. This wasn't the fault of the otherwise excellent NEX7. It was due to the lower quality NEX lens that was used to shoot its Studio images. It would probably have been much worse if DPR used the same Pentax lens on the NEX7 for the Studio sample images.
Don't know why you're mentioning this, can't use a different lens on the EX2.
Yet another demonstration of cluelessness or missing the point. It's not about interchangeable lenses, but about the fact that anyone, even trusted, reliable sources can sometimes post suspect images. In DPR's case, the original, full resolution images could be downloaded and they contained full EXIF data, which is how I determined that the aperture stated wasn't actually used, since the MF lens mounted with an adapter doesn't provide aperture information, but it could be inferred by knowing the shutter speed, the ISO used, and comparing it with other samples shot using different ISO values. The EX2f sample came with no source, no EXIF data, and were multi-shot crop composites that almost any fanboy could have kludged in minutes.
I was being flippant. Sense of humour override?
No, this is flippant :
adj. 1. Marked by disrespectful levity or casualness;
If you wanted to toss off a 'flip' remark you'd need to make it at least slightly obvious. Writing :
shows no sign of being a flippant remark. If that was your intent,
as opposed to being a face saving remark based on 20/20 hindsight,
Which it wasn't.
you again show that you haven't yet mastered English. Even tagging that line with a sometimes overdone smiley would have indicated a possible lack of seriousness. Fail.
I don't know why you've suddenly decided to start teaching English. Is "fail" a sentence? Or are you using it in the imperative?
I'm not sure why you bothered with your reply since an hour ago you wrote :
Me neither. "Since an hour ago", is that good English?
I'm now going to foxtrot oscar because life is too short.
Now would be a good time to start doing a Foxtrot. The Lindy (Hop) is a lot more fun though.
I like the way you turn debates into personal assaults, interesting. Is it because you are wrong on a few counts and can't admit it or is it because your mother breastfeed you?
http://www.flickr.com/photos/7467981@N05/
Tell the truth and shame the Devil, even though he doesn't really exist.
 The Jacal's gear list:The Jacal's gear list
Olympus SH-50 Olympus PEN E-P2 Olympus PEN E-PL1 Panasonic Lumix DMC-G5 Olympus PEN E-P1 +14 more
Billx08 Forum Pro • Posts: 11,373
You most certainly don't know English very well but you think that you do. That's very unfortunate and is bound to cause much future aggravation in your dealings with other English speaking people. I could say that you might be a moron. I could also say that you probably aren't a moron. They would be possible, plausible statements. I could also add that I'm pretty sure that you aren't a moron and that would also fit. But nowhere here or before did I ever say that "might" and "probably" have the same meaning. That's just your misinterpretation. You're not just wrong, you're mighty wrong, and I'm quite sure about that.
Why you continue to show your inability to grasp simple English is less a mystery than amusing. Languages evolve and English does more quickly than many. Perhaps I shouldn't have been so gentle and should have written " EPIC FAIL ". Does that make it any clearer? If not, here's a definition fer ya :
1. When something can be seen to be a total failure
2. Completely failed attempt to do something that would be considered rather simple.
More than good enough. Now you're resorting to bringing up red herrings in order to change the subject.
Most people would have thought that the videos those links pointed to were interesting and lots of fun. Considering the discussion we're having to be "personal assaults" just shows how far from reality you've come. Your own feeble attempts at verbal insults are also inept, or do you consider breast feeding to be something to be avoided or be ashamed of, and worthy of being used as an insult? The more you go on, the more you're leaving the impression that your "Jacal" ID should have been "Jacass", and whether you take that as an insult or not, it's too true to ignore. You may not be a little boy any more, physically, but like the snake, it appears that you'll never grow up. But you could try . . .
The Jacal
I like the way you turn debates into personal assaults, interesting. Is it because you are wrong on a few counts and can't admit it or is it because your mother didn't breastfeed you?
What I said about the lunatics running the asylum...
elliottnewcomb Forum Pro • Posts: 18,230
my wife hung this outside my office door:
 elliottnewcomb's gear list:elliottnewcomb's gear list
Sony RX1R Olympus Stylus 1s Sony RX100 VI Sony RX100 III Sony Xperia XZ +1 more
nx200USER1 Senior Member • Posts: 1,097
hehehehe.....at least your wife keeps things under control.
mine just takes the paycheck every week
Vince P
Vince P Senior Member • Posts: 2,890
Re: EX2F availability now September 12, 2012
 Vince P's gear list:Vince P's gear list
Sony RX100 VII Nikon D850 Panasonic GH5S Nikon Z7 II Nikon Z9 +81 more
cerberusjf Regular Member • Posts: 350
Gosh, that's a surprise, I wonder what's going on? Hopefully there'll be some reviews soon!! I'm a bit disappointed with the images I've seen so far, no reason for me to update from EX1 for sure apart from better frame rate and hopefully quicker start up. Hopefully the review images will be better.
inazuma11 Junior Member • Posts: 27
http://tech4tea.com/blog/2012/08/06/new-compact-camera-samsung-ex2f/
Update (23 August, 2012):
The Samsung EX2F is now available in Singapore.
Knallberto Veteran Member • Posts: 5,478
since one week available in Germany and UK
chris_j_l Regular Member • Posts: 355
And an order has been logged - my nephew, when confronted by evidence that he stole my EX1 (he was holding it) was unapologetic and refused to return it. My only option was to resort to Park cameras who are now sending me an EX2F :).
I'm getting soft in my old age.
C
Veducci Senior Member • Posts: 1,359
C
Well , congrats to you ! I hope you post some thoughts on it when it arrives and you get familiar with it. And of course some sample images would be nice.
 Veducci's gear list:Veducci's gear list
Fujifilm FinePix F40fd Panasonic Lumix DMC-GX85 Panasonic Lumix DMC-G3 Panasonic Lumix DMC-G5 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS +3 more
