7D Firmware update and My Menu
Started Aug 7, 2012 | Discussions
Art Guertin Regular Member • Posts: 160
Prior to installing the new firmware I had the usual 6 items in My Menu. After installing the firmware I now have only 5 items and cannot add another. There is a blank item space.
When I go through the list to remove 1 item it shows the last item added as being added twice. When 1 of these 2 items is deleted - it deletes both, but still will only let me add 1 for a total of 5 (with last item being duplicated but only showing up in My Menu once.
I sent an email to Canon support and hopefully they will have a remedy.
Anyone else encounter this problem?
'There is no limit to what a man can do so long as he does not care who gets the credit.'
-Philip Hyde (1922-2006)
 Art Guertin's gear list:Art Guertin's gear list
Canon Pixma Pro9000 Mark II Canon Pixma Pro9500
Canon EOS 7D
photojohne Contributing Member • Posts: 871
Re: 7D Firmware update and My Menu
Mine works, I can put in 6 items, and the 7th is for My Menu, then I can delete all 6 and add 6 others, seems to work fine on my 7D using the new firmware 2.0
WSSA # 165
http://www.johneasterly.com
 photojohne's gear list:photojohne's gear list
Canon EOS 7D Canon EF 17-40mm f/4.0L USM Canon EF 28-135mm F3.5-5.6 IS USM Canon EF 70-200mm F2.8L IS II USM Sigma 150-500mm F5-6.3 DG OS HSM
TTMartin
TTMartin Veteran Member • Posts: 7,304
Everything working fine after my update.
Have 6 items plus the my menu choice at the bottom for 7 total items. Same as before the update.
I formatted the CF card just prior to the update, and again, just after the update. Formatting seems to go faster now.
 TTMartin's gear list:TTMartin's gear list
Canon PowerShot S100 (2000) Canon PowerShot SD1000 Canon PowerShot G1 X Canon EOS 40D Canon EOS 400D +26 more
Cenk
Cenk Senior Member • Posts: 1,608
Take your battery out for 5 seconds and insert again... Try factory defaults etc...
 Cenk's gear list:Cenk's gear list
Nikon D700 Nikon D5000 Canon EOS 7D Nikon 1 V1 Canon EOS 70D +25 more
Karl Gnter Wnsch Forum Pro • Posts: 11,408
Probably you had Date/Time setting in the menu (which no longer exists in the old form) - you need to clear the My Menu... After that everything should be fine
regards
Karl Günter Wünsch
 Karl Gnter Wnsch's gear list:Karl Gnter Wnsch's gear list
Canon EOS 7D Mark II
OP Art Guertin Regular Member • Posts: 160
Re: 7D Firmware update and My Menu - Resolved
I deleted all the My Menu items, removed battery, waited, reentered My Menu choices and viola! It now functions correctly.
I sent Canon email with my remedy (in case someone else has the same problem).
Thanks all.
Tom McElvy Contributing Member • Posts: 875
No problems here - in without a hitch! (NT)
Tom McElvy
Virginia Beach VA USA
http://pbase.com/imagesbytom
http://flickr.com/tommcelvy
asu chic New Member • Posts: 10
Art and Karl,
I had the same problem. Did not have date and time in my menu, but had the
exact same issue. Clear your menu and re-enter your items and you will have
your six items back.
asu chic
TTMartin
Maybe I just never noticed it, but, this is the first firmware update that I remember that specifically states, that you should remove and replace the battery after the update.
MOD Dale Buhanan Veteran Member • Posts: 4,277
Re: No problems here - in without a hitch! (NT)
No problem here either. In without any problems at all and seems to be working perfectly.
Tom McElvy wrote:
kind regards
Dale
 Dale Buhanan's gear list:Dale Buhanan's gear list
Canon PowerShot SX50 HS Canon G1 X II Canon EOS 70D Canon PowerShot SD500 Canon PowerShot G5 +35 more
SeaScout851 Veteran Member • Posts: 6,342
Ran the update a few minutes ago. Everything seems to be fine.
Nice Job Canon!!!
Andy
David Naylor
David Naylor Contributing Member • Posts: 767
Does the firmware upgrade equal a factory reset? I.e. will all my C1, C2 & C3 be reset?
http://davidnaylor.org/photography/
http://davidnaylor.org/blog/
 David Naylor's gear list:David Naylor's gear list
Canon EOS 600D Sony a7 III Canon EF 100mm f/2.8 Macro USM Sony FE 55mm F1.8 Tamron 28-75mm F2.8 III
The upgrade left all my custom functions and lens MFA settings alone. No change.
kind regards
Dale
Robert Sheldon Senior Member • Posts: 2,180
I have made many Canon firmware updates going back to the 10D and they ALL required you to remove and replace the battery.
PS. They are infrequent enough that I print out and read the instructions each time I do an update.
Bob Sheldon
Photo Gallery at
http://www.bobsheldon.com
Old Sarge Regular Member • Posts: 194
I do the same thing. Been updating firmware for quite a few years but I still read the instructions....and even then I occasionally don't follow them well. At least once I put the FIR in the wrong directory.
The Old Sarge
jwhig Regular Member • Posts: 220
Art wrote:
"reentered My Menu choices and viola!"
But why would you want a viola in your menu, I wonder.
jwhig
 jwhig's gear list:jwhig's gear list
Canon EOS 7D Canon EOS 5D Mark III Canon EF 17-40mm f/4.0L USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-105mm f/4L IS USM +4 more
wihakowi Regular Member • Posts: 242
jwhig wrote:
Art wrote:
Do you mean as opposed to a piano or bass drum? I would say that each 7D should have the right to choose the musical instrument of their choice to have on the "My Menu" choices.
AND
Canon, with FW2 has improved the experience with changes to "Sound recording manual adjustment!" You can have your viola and hear it too!
 wihakowi's gear list:wihakowi's gear list
Canon EOS 7D Canon EOS 600D Canon EF 50mm f/1.4 USM Canon EF 100mm f/2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM +8 more
KWEnz Regular Member • Posts: 378
wihakowi wrote:
jwhig wrote:
Art wrote:
--"reentered My Menu choices and viola!"
jwhig
AND
Good to see he's using a viola and not a walla as I've seen being used in other posts on dpreview. A sound choice of word instead of voilà you'll no doubt agree!
Ken
 KWEnz's gear list:KWEnz's gear list
Canon EOS 7D Mark II Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF 100mm f/2.8 Macro USM Canon Extender EF 1.4x II Canon EF 24-105mm f/4L IS USM +14 more
KWEnz wrote:
wihakowi wrote:
jwhig
AND
Ken
It's all music to my ears.
But he might just be going with the flower!
jwhig
