DIY: NX AF Macro Tube Set: Design and Real Parts
Started Jul 31, 2012 | Discussions
ihkim Regular Member • Posts: 451
I am DIYing AF-Macro tube set for NX system.
First 3 pictures show the design of the macro tube. It is 22mm. I am planning to make 14mm and 32mm tube, too. So, it will cover tube length from 14mm to 70mm.
Rest 3 images are real part from the design. It is made of plastic, but strong enough for real use.
 ihkim's gear list:ihkim's gear list
Samsung NX10 Canon EOS 550D Samsung NX100 Samsung NX20 Samsung NX300 +5 more
OP ihkim Regular Member • Posts: 451
Re: DIY: NX AF Macro Tube Set: Image Samples
NX 18-55 lens + 22mm Macro Tube
NX 50-200 lens + 22mm Macro Tube
tecnoworld
tecnoworld Veteran Member • Posts: 7,232
Re: DIY: NX AF Macro Tube Set: Design and Real Parts
interesting. If used with the 60mm should it produce more than 1:1 images?
can it also be used with 50-200mm lens? what's the magnification factor at 100mm?
 tecnoworld's gear list:tecnoworld's gear list
Samsung TL500 Samsung NX100 Samsung NX200 Samsung NX300 Samsung NX1 +15 more
I am not familiar with the magnification factor. Basically, with the tube, you can focus closer objects. Thus the object will be shown bigger and bigger.
Yes, it can be used with any NX lens.
tecnoworld
if you can focus closer, and since the 60mm is already 1:1 macro, then with this extension tube it will give a magnification factor higher than 1:1. This is nice. The only drawback with tubes is that dof gets tiny and it's very difficult to keep items in focus.
what will the cost of this tube be, more or less?
Michael Barker Senior Member • Posts: 1,966
Are you 3D printing this?
paulhome Contributing Member • Posts: 841
cool stuff. Looks very well made as well. If i saw it on ebay i'd want it
 paulhome's gear list:paulhome's gear list
Fujifilm X-E1
Yes, I am.
v12nut Regular Member • Posts: 293
What is the material used for the contact pins? and are they spring loaded?
Good job!
Tom
Cool! Does the OIS work also?
Good job!
Tom
They are pogo test prove which are usually used for testing electronic circuits.
Definitely! All mount contacts are alive. OIS, DMF, AF, AE.. you name it.
hootsmon
hootsmon Contributing Member • Posts: 903
I agree. I believe this would be very saleable.
 hootsmon's gear list:hootsmon's gear list
Samsung NX11 Samsung NX30 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 85mm F1.4 ED SSA +1 more
tecnoworld
Will you sell them?
ellepi New Member • Posts: 20
Excellent work.
I'm very interesting in this and into your other project: the AF adapter ring.
Daniel1977
Daniel1977 Senior Member • Posts: 1,013
http://www.samsungcamera.com/producer-interview-how-the-nx-extension-tube-came-to-birth/
Powered by Samsung:
NX20, NX200, NX10, EX1, 20mm, 30mm, 18-55mm, 50-200mm, 60mm, reverse Mount Adapter, Galaxy Note
Prints for buy: http://daniel-kulinski.artistwebsites.com/
All of my works: http://www.flickr.com/photos/didmyself/
Available for commercial use on Getty Images http://artist.gettyimages.com/link/6865853
 Daniel1977's gear list:Daniel1977's gear list
Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 20mm F2.8 Pancake Samsung NX 50-200mm F4-5.6 OIS Samsung NX 16mm F2.4 Pancake +5 more
Desverger Regular Member • Posts: 124
3D printers, FTW!
Looks good! I'd certainly want one. Obviously it would be quite time consuming for one person mass producing them (or even producing just 50 of them). Any plans to release the schematics and allow anyone with a 3D printer to print these off? Some assembly would still be required of course... As long as the cost is less than the 60mm macro lens, it would make sense.
 Desverger's gear list:Desverger's gear list
Canon PowerShot SD550 Samsung NX1000 Samsung NX300 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS +4 more
Alexramos
Alexramos Senior Member • Posts: 1,602
Using a 60mm Macro lens with the 22mm extension tube will offer a 82mm macro with a magnification higher than 1:1.
travelinginthestates.blogspot.com
streetsinblackandwhite.blogspot.com
Alexramos
Excellent job... just let me know when they sill be sold...
monkeybrain Regular Member • Posts: 424
Really brilliant! I'd really like to get my hands on one of those too! It's great that samsung are writing about it too.
 monkeybrain's gear list:monkeybrain's gear list
Samsung NX10 Samsung NX100
