My 3600Hs(D) wont power on should I fix or replace
Started Jul 29, 2012 | Discussions
Guimar Forum Member • Posts: 75
I haven't used my 3600hs(D) in a while.
I stores it without batteries.
I have tried 2 sets f alkaline batteries(inserted as per the manual),
and it wont power on.
Is it worth trying to fix or can somebody recommend a cheap flash with similar performance (camera is A33)?
I have had the flash for a long time, started using it with a Minolta A2.
EvilOne
EvilOne Forum Pro • Posts: 14,482
Re: My 3600Hs(D) wont power on should I fix or replace
I checked your profile and I think your priorities lie with Panasonic, but that is fine... I would not invest too much money, but you could try to make sure the contact points in the 3600 are really clean...you can use some electrical contact cleaner.. if you see any corrosion you might want to get a emery stick, like those used to manicure fingernails.. and sand the contacts until they are clean. As far as getting a New flash, rather than offering opinion, why not tell us what you are willing to spend on a New flash... the other suggestion would be going to KEH and try to buy a used one..
Bill aka EO
 EvilOne's gear list:EvilOne's gear list
Minolta DiMAGE 7Hi Nikon Coolpix 990 Konica Minolta Maxxum 7D Sony Alpha DSLR-A700 Sony SLT-A77 +5 more
HobbiesAreFun Senior Member • Posts: 2,457
If you can fix it for under $70, fix it. Otherwise? Get a good used one for no more than $80 including shipping.
-Eric (17 years old with tons of things I can't wait to learn)
http://eswenson.smugmug.com
 HobbiesAreFun's gear list:HobbiesAreFun's gear list
Nikon D800E Nikon AF-S Nikkor 28-70mm f/2.8 ED-IF Sigma 50-500mm F4.5-6.3 DG OS HSM Nikon AF-Nikkor 80-200mm f/2.8D ED Samyang 14mm F2.8 IF ED MC Aspherical +3 more
Undah Veteran Member • Posts: 5,330
look up capacitor reforming.
Basically, put freshly charged batteries and turn it on for at least 10 minutes. That should bring it back to life if it is not dead.
OP Guimar Forum Member • Posts: 75
I tried the battery trick, it looks like it is really dead...
The contacts are in good shape,
It was a nice flash when used with the Minolta A2.
Corkcampbell
Corkcampbell Forum Pro • Posts: 18,038
Used ones are cheap; just check ebay.
I think that I paid about $65 for one about 3 or 4 years ago, and bought the Sony version 3 years ago at Best Buy for $90 (demo unit). My original one, also bought used, was for an A2. All still work fine and are compatible with my newer cameras. Good units.
 Corkcampbell's gear list:Corkcampbell's gear list
Sigma DP2 Merrill Sony Cyber-shot DSC-RX10 Sony RX100 III Panasonic Lumix DMC-GH3 Panasonic Lumix DMC-GH4 +5 more
