my Tokina AF 100mm f/2.8 AT-X M100 Pro D Macro Lens not auto focusing
Started Jul 27, 2012 | Discussions
Marilole New Member • Posts: 4
Hi guys
I just received my Tokina AF 100mm f/2.8 AT-X M100 Pro D Macro Lens and it is not autofocusing on my D7000 (when I use it as a short telephoto). Does anyone has an idea how to fix this? any answer will be appreciated.
When I am shooting macro, I will use it on manual focus.
Mo59 Junior Member • Posts: 48
Re: my Tokina AF 100mm f/2.8 AT-X M100 Pro D Macro Lens not auto focusing
Don't suppose it is something as similar as the limiter switch? It should autofocus with the D7000 so, as I say, try the focus limiter switch and if that doesn't work sounds like a fault.
 Mo59's gear list:Mo59's gear list
Tokina AT-X Pro 11-16mm f/2.8 DX Tokina AT-X Pro 50-135mm f/2.8 DX Tokina AT-X Pro 35mm f/2.8 Macro DX
fotowbert
fotowbert Senior Member • Posts: 2,737
Push Pull AF Switch
Your problem might be the unique Tokina push pull AF/MF switch action associated with the focus ring.
I have on occasion overlooked this and wondered why my lens AF didn't work! John
Marilole wrote:
Hi guys
 fotowbert's gear list:fotowbert's gear list
Canon PowerShot A20 Canon PowerShot SD870 IS Fujifilm FinePix F31fd Panasonic Lumix DMC-LZ8 Canon PowerShot S95 +15 more
OP Marilole New Member • Posts: 4
Re: Push Pull AF Switch
Thanks all! I appreciate it
