Why No Self-Timer Available with HDR Shooting?
Started Jul 26, 2012 | Discussions
Jerry Canon
Jerry Canon Contributing Member • Posts: 875
I'm just trying to figure out why Sony chose to not make the self-timer function available when shooting HDR exposures. It could be so handy there so you could set the camera down and let it time itself off to avoid having to hand hold it and induce camera movement. Surely there's some practical reason for this that just hasn't occurred to me, otherwise why wouldn't this be available?
http://500px.com/JerryBrendle
 Jerry Canon's gear list:Jerry Canon's gear list
Sony RX100 III Sony Alpha a7 II Sony FE 55mm F1.8 Sony FE 70-200 F4 Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS +1 more
D Cox Forum Pro • Posts: 20,857
Re: Why No Self-Timer Available with HDR Shooting?
Jerry Canon wrote:
It is simply a mistake by the person/people who coded the software.
I doubt if these coders have much experience of photography.
It is certainly high time it was fixed, but this does require some rethinking of the menu structure.
Limbery Forum Member • Posts: 53
Perhaps it could be implemented in the new firmware upgrade?
Mike Wee Contributing Member • Posts: 662
+1
There simply is no reason. This is actually an insight into the minds of the UI developers at Sony that might explain some of the other facepalm-inducing decisions they have made. It points to sheer incompetence.
Ex-Tee-Eye * 50 1,8 * 17-85
En-Ee-Ex-5 * 16 * 18-55 * 55-210 * CV 35 1,4 * FD 50 1,4
 Mike Wee's gear list:Mike Wee's gear list
Sony RX100 II Canon EOS 400D Sony Alpha NEX-5 Sony a6000 Canon EF-S 17-85mm f/4-5.6 IS USM +11 more
jemez Forum Member • Posts: 67
Does remote activation work in HDR mode? I haven't looked at this.
Jerry Canon
OP Jerry Canon Contributing Member • Posts: 875
Good question, I haven't tried it. I'll have to give it a try.
sasoph Regular Member • Posts: 433
Don't forget to complain:
sonylistens@am.sony.com
you will doubtless be fobbed off with grateful thanks and informed that your suggestion has been forwarded to the development team.
Bah!
 sasoph's gear list:sasoph's gear list
Sony Alpha NEX-7 Canon TS-E 17mm f/4L Canon TS-E 90mm f/2.8 Canon MP-E 65mm f/2.5 1-5x Macro Canon TS-E 24mm f/3.5L II +51 more
I tried no remote either. That is seriously bogus.
DezM
DezM Forum Pro • Posts: 34,528
Found that out months ago. Very disappointing.
Dez
http://dezsantana.com
 DezM's gear list:DezM's gear list
Nikon D850
DtEW Senior Member • Posts: 2,636
I thought into why things are as they are.
My conclusion is that they oversimplified the UI into a single menu selection, whereas we'd have been satisfied with a double-selection menu.
What do I mean?
Current structure - choose one:
Single - Continuous - Continuous Speed - Bracket - Timer - Remote.
This precludes using any mode in conjunction with each other.
The better way to do this would be a parallel, double-selection menu.
Proposed structure - choose one from this menu:
On a parallel scrolling menu, choose another:
Normal - Timer - Remote
Being that you're using the D-pad up-down to operate the menu anyways, allowing it to go left-right to navigate between the two parallel menus should be easy and intuitive.
 DtEW's gear list:DtEW's gear list
Canon EOS 6D Canon EOS 5DS Canon EF 28-135mm F3.5-5.6 IS USM Samyang 24mm f/1.4 ED AS UMC Canon EF 24-70mm f/2.8L II USM +16 more
