Will EF-M lens work on DSLR?
Started Jul 23, 2012 | Discussions
gsmayes Regular Member • Posts: 145
I have a T3, any idea if the new EF-M 22mm STM f/2 lens can be made to work on it? Or would the extra adapters make it just as big as the 35mm f/2?
I'm moving to Queens in the near future, and really wish Canon made a 15mm pancake lens. That would make my T3 close to pocketable, and much less conspicuous as I explore the city. The 35mm f/2 is still too big to pocket, and not wide enough for the cavernous streets of Manhattan. I fear even 22mm would still be too narrow.
Unless they come out with something, I think I'll be forced to buy a NEX or 3/4 with pancake and relegate the T3 to niche macro and telephoto use.
 gsmayes's gear list:gsmayes's gear list
Canon EOS RP Canon RF 35mm F1.8 IS STM Macro Canon RF 15-35mm F2.8L IS USM Canon RF 24-70mm F2.8L IS USM Canon EOS 70D +14 more
Badbatz Senior Member • Posts: 1,914
Re: Will EF-M lens work on DSLR?
Yes, it will after you hack the mirror and some other parts out of your DSLR...
Seriously, read the specs: what is the flange (registration) distance of the new M lens and your EF lens..?
gdanmitchell
gdanmitchell Veteran Member • Posts: 7,991
Guessing (educated guess) that the answer will be no. The back of the M lens mounts much closer to the sensor, and is designed for a sensor to mount distance that is much shorter than that of EF and EFS lenses.
Dan
(unknown member) Veteran Member • Posts: 5,590
I suspect it was a serious question that deserves a serious answer. Perhaps not everyone is as knowledgeable as you and fully understands what flange distance means even if they had read the specifications ............?
carlk Forum Pro • Posts: 15,940
No. The mirrorless has much shorter registration distance (back element to sensor) distance, which is one of the main reasons for mirrorless.
 carlk's gear list:carlk's gear list
Canon EOS 50D Canon EOS 7D Nikon D800E Fujifilm X-E1 Canon EF 85mm F1.2L II USM +6 more
CameraCarl Veteran Member • Posts: 9,204
Doesn't the announcement say Canon introduced a new lens mount with the camera and lenses?
Yes but Canon is also releasing an EF to M adapter. The reverse (M to EF/EF-S) can not be made though because M-mount lenses sit closer to sensor.
Pardon me, Milord, for offending your sensibilities. I shall sin no more.
C'mon, that's why there are glossaries (including the one on this site) and other sources. Not every question deserves a verbose answer that pretty much copies verbatim what's already out there.
OP gsmayes Regular Member • Posts: 145
I looked on the interweb but didn't find an answer.
If you feel put out, please send a bill to:
Internet Tough Guy
C/O Why did you click Industries
1212 Relax Blvd
Jerktown, Yousville, 12121
Shorthand Senior Member • Posts: 2,976
No it definitely will not work and cannot be modified to work. As mentioned above, it would need to be mounted inside of the camera.
Unfortunately, there is no way to make a 15mm pancake lens for a DSLR. Instead one must use a large and cumbersome retrofocus (reverse telephoto) design as the back of the lens (back focus distance) can't be closer than about 40mm to the sensor.
More info can be found here: http://www.lensrentals.com/blog/2011/03/the-development-of-wide-angle-lenses
Consider yourself forced.
I thought this was a good guide to street photography on a budget:
http://www.adorama.com/alc/0013731/article/Digital-Cameras-for-Street-Photography-An-Opinionated-Buying-Guide
I honestly wonder how the Sony RX100 or Canon G1X would do for you as well ... street photography is a hyperfocal business in the first place.
 Shorthand's gear list:Shorthand's gear list
Sony RX100 Canon G7 X II Canon EOS 300D Canon EOS 450D Canon EOS 500D +13 more
GordonAtWork
GordonAtWork Regular Member • Posts: 482
I'm thinking EF-M to XL adapter.
With a stepper motor for focus I think that could be better than the electric focus system used which is not very accurate in it's operation (focus speed depends on speed of rotation of the focus ring but is not directly related to how far you rotate it). AF is disabled on the EF-XL adapter (ok, pro's don't use AF, do they ?) but amateurs like me think it could be useful, after all the standard lenses for the XL1s are AF.
Funnily enough, the image stabiliser does work on EF lenses.
Moderator wannabe !
 GordonAtWork's gear list:GordonAtWork's gear list
Canon EOS-1Ds Mark II Canon EOS D60 Canon EF 20mm f/2.8 USM Canon EF 50mm F1.4 USM Canon EF 400mm f/5.6L USM +9 more
gdanmitchell
Well, now, not unless they bring out the rumored negative length adapter...
mttamborine New Member • Posts: 1
Internet Tough Guy
1212 Relax Blvd
I agree. Why bother to type a response?… unless of course the intention is to belittle a person for asking a simple question.
Dave
Dave Veteran Member • Posts: 6,231
Internet Tough Guy
1212 Relax Blvd
I’ll risk doing the same.  Why chime in on a nearly eleven year old thread?
 Dave's gear list:Dave's gear list
Canon EOS 80D Canon EF 135mm F2L USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-300mm f/4-5.6L IS USM +10 more
EduPortas Contributing Member • Posts: 838
gsmayes wrote:
No. They are not back-ward compatible. Canon made pretty sure you couldn't use one of their exclusive M lenses on their older DSLR technology.
It was a good move for them. It now forces us to buy RF tech.
