EOS Utility won't recognize 5DIII - Windows 7 64-bit
Started Jul 21, 2012 | Discussions
SDRebel Senior Member • Posts: 1,489
Windows 7 64-bit is listing my 5DIII as a portable device. I can read the cards and download without a problem.
However, EOS Utility won't recognize my 5DIII. I have the latest version and didn't have this problem with my previous 32-bit computer.
Canon so far hasn't been able to offer any suggestions.
Are there others having this problem?
I've uninstalled and reinstalled EOS Utility and plugged the 5DIII into several USB ports using different cords.
In the past Autoplay would come up when I plugged in the camera. It no longer does which I suspect is because the camera is listed as a portable device rather than a device with removable storage.
So far I can't figure out a solution. Any thoughts?
Steven Blackwood Senior Member • Posts: 1,711
Re: EOS Utility won't recognize 5DIII - Windows 7 64-bit
Are you using a hub. If so, try plugging the camera directly into the pc's USB port.
Steve
anasazi@wi.rr.com
Milwaukee WI
 Steven Blackwood's gear list:Steven Blackwood's gear list
Canon EOS M50 Canon EOS R Canon EF-S 18-135mm F3.5-5.6 IS USM Sigma 100-400mm F5-6.3 Canon EF 70-200 F4 II +1 more
focal Regular Member • Posts: 218
You need the version off the CD that came with the 5D3.
Canon proudly defends this long known, stupid error.
