WB850f cannot access WiFi settings
Started Jul 14, 2012 | Discussions
t54skyblue New Member • Posts: 1
Forgive me if this is in the wrong place, and i've been trawling the entries and cannot find an answer.
I've just bought a WB850F Samsung camera and tried to set up WiFi. I've followed the PDF manual (turn the dial to Wi-Fi, select an appropriate mode, then press MENU), but pressing menu has no effect.
Can anyone help me please ?
WiFi connectivity was a key purchasing factor.
Samsung WB850F
RL Wood New Member • Posts: 2
Re: WB850f cannot access WiFi settings
It's not very intuitive. Each WiFi function has its own behavior. For example, the mobilelink and remote viewfinder use wifi direct and the others use normal wifi over a router. Try this: go to Social Settings and then press menu. You should be able to connect to your wifi router.
Stick with it and experiment a lot. It's a great camera and I love the pictures and the functionality.
