GX10 firmware 1.3 fault?
Started Jul 4, 2012 | Discussions
enonod Junior Member • Posts: 34
The GX10 has the function as do all cameras of focusing on shutter press.
It also has an AF button that can be menu set to autofocus or not.
When the latter is set to ON the shutter release focus should disable but does not.
This renders the AF button pointless.
The above info is confirmed in the Samsung D-Xenon 100 Macros lens user manual.
Has anybody solved the problem of not disabling the shutter focus action or is it indeed a firmware bug?
For the bird's and small animal's sake, please cut all plastic loops in 4 can retainers before going to land fill.
Samsung GX-10
dlacoutu Contributing Member • Posts: 811
Re: GX10 firmware 1.3 fault?
If it's anything like its Pentax sibling, I think you have to "disable AF on shutter half-press" in the custom menu.
These buttons are in fact configured separately.
 dlacoutu's gear list:dlacoutu's gear list
Samsung NX100 Pentax K-5 Samsung NX200 Pentax smc FA 50mm F1.4 Samsung NX 30mm F2 Pancake +6 more
OP enonod Junior Member • Posts: 34
Thank you very much for that, I could not see it for looking, perhaps I expected different wording.
It works fine now!
