WB850F Has seized
Started Jul 1, 2012 | Discussions
algeee New Member • Posts: 4
WB850F Has seized
I am learning the functions of my new camera. I have successfully installed the updated firmware on it. I was trying the red eye function. I took a picture in 'P' mode and then pressed the playback button. The screen went out, the green light stayed on, the lens are extended and I am unable to switch the camera off by using the power button.
What can I do from here?
Samsung WB850F
boninsegni
boninsegni Regular Member • Posts: 436
Re: WB850F Has seized
Try to take out the battery, wait a few seconds and put it in again.
Normally it reset your camera.
Hope it helps!
Christian
 boninsegni's gear list:boninsegni's gear list
Sony Cyber-shot DSC-TX30 Panasonic Lumix DC-ZS70 Panasonic ZS200
OP algeee New Member • Posts: 4
It appears to have fixed it. I will have another play with it tonight. Thank you.
DomT Senior Member • Posts: 1,176
My WB850F would lock up too when I did not install the firmware upgrade properly.
DomT NZKiwi
Everything seemed to go as it should have with the firmware install. The camera turned itself off as the instructions said it would. The GPS sorted itself when I turned it on again.
How did you reinstall the firmware; just overwrite what was on it?
