WB210 , how does it achieve 21mm wide equivalent? Switching built in lens?
Started Jul 1, 2012 | Discussions
geminihc Regular Member • Posts: 283
im thinking of getting the wb210 for ultra wide shots while still having a compact package. additionally,. the 12x zoom is a bonus. im curious how it can do it with such a thin depth in the camera tho? does it literally switch to another fixed 21mm lens inside? i read somewhre that the 21mm isn't really 21mm and almost just as wide as other 24mm cameras.. is this true?
i wonder why no other cameras do this? is there some kind of disadvantage? I think it would be cool if more other compacts have even wider built in features like this.
thanks!
Samsung WB210
Alexramos
Alexramos Senior Member • Posts: 1,602
Re: WB210 , how does it achieve 21mm wide equivalent? Switching built in lens?
thanks!
It is a real 21mm, you choose the 21mm option from the menu and you can hear the lens moving to that position.
Normally this camera is a 24mm.
travelinginthestates.blogspot.com
streetsinblackandwhite.blogspot.com
WJMWJM Regular Member • Posts: 161
thanks!
The disadvantage, at least the way Samsung implemented it, is that it allows hardly any combination with other functions/adjustments/settings, not even video.
More details & ponderings about this in an earlier posting today:
http://www.dpreview.com/forums/thread/2987089#forum-post-56105808
