HX20v does jungle critters
Started Jun 27, 2012 | Discussions
Joe M Amadas Regular Member • Posts: 181
Well I got a HX20v after some good reviews and some good results I saw.
... and I got her for less than I payed for my HX5, so I had to buy one ...
Here are her first shots outside the home.
They are mostly ISO 800 and 1/15 or slower handheld
Sony Cyber-shot DSC-HX20V Sony Cyber-shot DSC-HX5
Helena777
Helena777 Forum Member • Posts: 95
Re: HX20v does jungle critters
Very pretty pics Joe. And the technical quality surprises me for the little sensor of the cam.
One golden glance of what should be...
 Helena777's gear list:Helena777's gear list
Sony Alpha NEX-5 Sony Alpha NEX-3 Sony Alpha NEX-7 NEX-5T Pentax K-S1 +5 more
Michael Kalm Regular Member • Posts: 278
Marvelous! And in number 2, you did a great job of getting the camera to focus on exactly what you wanted it to focus on. Kudos!
66 on the outside, 18 on the inside
aaanouel
aaanouel Veteran Member • Posts: 5,107
Excellent job José.
That little camera does very good shots, congrats!
Keep'n posting them.
Txs4Sharing
aaanouel
Truth is a pathless land.
The dead past darkens the ever living present.
Corrections and critics are more than very welcome, desirables.
 aaanouel's gear list:aaanouel's gear list
Sony Cyber-shot DSC-P73 Sony Cyber-shot DSC-HX100V Sony SLT-A65 Sony DT 18-250mm F3.5-6.3 Adobe Photoshop CS6 +21 more
ASR45
ASR45 Forum Pro • Posts: 36,616
Excellent mate.--
Alan.
 ASR45's gear list:ASR45's gear list
Canon EF 100-400mm F4.5-5.6L IS II Nikon D750 Nikon D500 Pentax KP Nikon AF Nikkor 80-400mm f/4.5-5.6D ED VR +8 more
OP Joe M Amadas Regular Member • Posts: 181
some more HX20v jungle critters
I was amazed how well the HX20v is able to focus in low light / low contrast situations.
As usual if you shoot under not good situations there are few focus error pictures but over all for the first set of images Sony did a pretty good job with this camera.
Re: some more HX20v jungle critters
Dutchpepper
Dutchpepper Senior Member • Posts: 1,505
You and the camera did a really good job very nice indeed, Nice to see you enjoying the Hx20v Joe and look forward in seeing lots more!
Craig
http://www.flickr.com/photos/loubella/
 Dutchpepper's gear list:Dutchpepper's gear list
Sony a5000 Sony a6000 Sony E 16mm F2.8 Pancake Samyang 85mm F1.4 Aspherical IF Sony E 30mm F3.5 Macro +6 more
ISO 800 1/6 sec handheld no flash 4x zoom
The 20 x lens is able to capture the same frame from up to 4 x as it does from 1 x and 1 cm distance.
So if you like macro shooting like I do you can use it up to 4 x.
The 1 cm minimum distance is not correct, you can in fact nearly touch the subject with the lens, just rest the lens barrel rest on your skin and tilt it to 45 degrees and see how well it focuses.
dalemccl Contributing Member • Posts: 526
Very nice! You must have very steady hands to get sharp shots at such slow shutter speeds (1/6 in one case).
 dalemccl's gear list:dalemccl's gear list
Panasonic Lumix DMC-G7 Panasonic Lumix DMC-GX85 Panasonic 12-35mm F2.8 Panasonic Lumix G Vario 14-140mm F3.5-5.6 ASPH. / Power O.I.S Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS +8 more
Sam_Oslo
Sam_Oslo Veteran Member • Posts: 3,022
Nice shots and cute green creatures.
 Sam_Oslo's gear list:Sam_Oslo's gear list
Sony SLT-A77 Sony 50mm F1.4 Sony 20mm F2.8 Tamron SP AF 90mm F/2.8 Di Macro +2 more
ASR45
Scary dudes
Alan.
In low contrast situations and shady areas the 18 MP sensor of the HX20V looses and smothers detail.
With 50% reduction per side you have a quite astonishing 4.5 MP result.
Now add a little post processing (I use the free FastStone Image Viewer and with most the pictures above Gamma to .8 - .9, Contrast +10, Saturation +10 and Sharpness +15 - 18)
http://hx20v.blogspot.com
ASR45
Very good Joe
Alan.
last of the HX20v jungle critters
looks like you enjoyed looking at them as much as we did capturing them.
I found them in one of our malls as an exhibition. They were behind smudged glass in their typical environment what mostly was not too well lit - except for the horned snake.
We did the best to shield the lens from the reflection of the glass and sure added to the smudging during the shielding.
When possible we used the glass as a mono-pod to stabilize the camera.
The HX20V did all the automatic measuring and setting.
We tried to give the pictures the feel as if they were shoot in the nature.
ASR45
Re: last of the HX20v jungle critters
Great well done
Alan.
sparkle1103
sparkle1103 Veteran Member • Posts: 3,654
RReally great shots. Love the expressions you caught on their faces.
Janice
In Loving Memory of
Sparkle
July 4, 1993 to August 14, 2011
