Is it possible to clean the sensor on a Point & Shoot?
Started Jun 25, 2012 | Discussions
Birk Binnard
Birk Binnard Senior Member • Posts: 1,982
Model DMC-ZS8 has 3 gray spots that show up on all stills & videos. Must be some junk on the sensor, yes? Is there a way to clean it off?
Birk Binnard
http://www.birkbinnard.com/photography
snap
snap Veteran Member • Posts: 6,211
Re: Is it possible to clean the sensor on a Point & Shoot?
I took apart my FX580 last year to remove a dust lodged on the sensor. It's not too difficult - just remember which screws you've removed - I took photos as I proceeded.
And be very gentle with the ribbon cables that the LCD is attached. I came across this video on Youtube which is very helpful. Watch this: http://www.youtube.com/watch?v=q_sP4yLf6lA
Rick
 snap's gear list:snap's gear list
Olympus C-8080 Wide Zoom Panasonic Lumix DMC-FX700 Olympus XZ-1 Fujifilm X10 Fujifilm X-S1 +48 more
VadymA Senior Member • Posts: 1,590
I saw a suggestion to put the camera on something that provides mild vibration, like a washing machine, etc. I've never tried it myself but I did "removed" one nasty spot when leaning forward with a camera on a neck strap and accidentally bumping it againt a table.
So I think it might work. Worth a try before taking it apart.
Birk Binnard
 VadymA's gear list:VadymA's gear list
Nikon D300 Nikon 1 J5 Nikon AF Nikkor 85mm f/1.4D Tokina AT-X Pro 11-16mm f/2.8 DX Nikon AF-Nikkor 80-200mm f/2.8D ED +7 more
johnno02 Regular Member • Posts: 105
Sorry,
I cant answer your question,but after having a similar experience with a cheap point,and shoot Camera I was very fond of for Digiscoping,I now have a couple of Golden Rules.
1 Always turn Camera on,with Lens pointing down.
2 Always turn Camera off with Lens pointing down,AFTER,blowing any foreign materials off the Lens area.
My reasoning,is, if anything has settled on the extended lens tube,Hopefully,it wont be drawn inside the Camera,if the Lens is pointed down when retracted.
John
