D800 cheap battery pack's
Started Jun 20, 2012 | Discussions
cosmicnode Veteran Member • Posts: 4,096
For those interested there are Pixel vertex and Meike battery packs available for the D800 and E bodies available on eBay, I find that the body fits my long fingered hands very well unlike previous non pro Nikon's which required a battery pack to feel comfortable. I will probably buy one of these for the occasions I need 6fps in DX for motorsport, but will not leave it fitted at all times. These appear to be the same item sold under different names. I know these will not be the same quality as the Nikon original but will be useful for occasional use with AA batteries.
http://www.ebay.co.uk/itm/Meike-Battery-Holder-Grip-Battery-Grip-for-Nikon-D800-D800E-/120936034277?pt=UK_Camera_Battery_Grips&hash=item1c28596fe5
http://www.ebay.co.uk/itm/Pixel-Vertax-D12-Battery-Grip-for-Nikon-D800-D800E-MB-D12-DSLR-ENEL15-MBD12-E507-/290731747365?pt=UK_Camera_Battery_Grips&hash=item43b0f66825
Mike.
"I say we take off and nuke the entire site from orbit, it's the only way to be sure."
 cosmicnode's gear list:cosmicnode's gear list
Nikon D300 Nikon D800 Nikon D500 Olympus E-M1 II Olympus E-PL8 +12 more
Nikon D800
bkushner Contributing Member • Posts: 550
Re: D800 cheap battery pack's
Don't you need the D4 battery to get the increased frame rate? Will the knock offs hold the d4 battery?
http://www.flickr.com/photos/bkushner/
BeachnCruz Senior Member • Posts: 2,034
Re: D800 Pixel Vertex and Meike battery Battery Grip Packs
Will the Pixel Vertex or Meike Battery Grip Packs designed for D800 work with an En-El18 D4 Battery also ?
Will a Nikon BL-5 Battery Adapter Cover (intended for use with En-El18 Battery when adapted to the Nikon D800 Grip) fit aftermarket Pixel Vertex or Meike Battery Grip Packs?
Will the Really Right Stuff or Kirk L-Bracket/Plate designed for use with Nikon D800 + Nikon Battery Grip Pack also fit D800 if using an aftermarket Pixel Vertex or Meike D800 Battery Grip Pack ?
OP cosmicnode Veteran Member • Posts: 4,096
I think you can get the extra frame rate from the 8AA batteries
Mike.
RicAllan Contributing Member • Posts: 795
Re: D800 cheap battery pack's (Observation and Question)
Mike.
In looking at specs, it seems that the 'off brand' units use 6 AA batteries instead of the 8 the Nikon unit does... has anyone purchased one toand can they verify...???
Ric
 RicAllan's gear list:RicAllan's gear list
Nikon D4S Nikon D810 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 24-120mm F4G ED VR Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +2 more
DANdeMAN
DANdeMAN Senior Member • Posts: 1,001
Pixel = 8 AA
According to my "investigation" lol the Pixel battery pack hold 8 AA units.
Read all about it here : http://www.pixelhk.com/Proshow.aspx?id=184
Is the Meike another company or is it the same case with a different name?
To be safe I would go with the Pixel one... If ever I do get one.
DANdeMAN SONY V3 (03-2005) - D800E on pre-order
 DANdeMAN's gear list:DANdeMAN's gear list
Nikon D800E Samyang 14mm F2.8 ED AS IF UMC Nikon AF Nikkor 50mm f/1.8D +10 more
DANdeMAN
I have contacted the Pixel Vertax ebay seller with my findings and they have modified the description to 8AA instead of 6AA. They have confirmed this via an email to me.
http://www.ebay.ca/itm/290731747365?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_2171wt_1044
Darren Langdon
Darren Langdon Contributing Member • Posts: 760
The Pixel version seems better quality than the Meike version because of the metal pin versus a plastic one on the Meike grip.
One should never 'take' a photo but rather make one.....the only thing you should take is your time.
FCAS Member #104
 Darren Langdon's gear list:Darren Langdon's gear list
Nikon D810 Nikon D850 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Teleconverter TC-14E II Sigma 35mm F1.4 DG HSM Art +9 more
I ordered one....
Ric
DANdeMAN
RicAllan wrote:
I ordered one....
Keep us abreast of your findings/evaluation....
Ariftjioe New Member • Posts: 5
Is it really can hold 2 EN-EL15?
They also mention it use the same raw material with the camera body. Is that mean it's made out of magnesium alloy instead of plastic?
I have ordered the Meike battery pack , I think that there has been confusion between different sellers about the number of AA batteries the grips hold, some saying 6 and others 8. however all appear to show the same 8 cell holder.
There are also batteries advertised to fit D7000 battery packs which may become available for the D800 pack "EN-EL15A" at 3400mah the Nikon battery is rated at 1700mah
http://www.ebay.co.uk/itm/EN-EL15-EN-EL15A-BATTERY-FOR-NIKON-MB-D11-D7000-GRIP-/300553946920?pt=UK_Camera_Batteries&hash=item45fa694728 This may give the higher frame rate similar to the AA batteries and the battery from the D4
Mike.
spbStan
spbStan Senior Member • Posts: 1,959
The Mieki has a metal locator pin also. I like mine on the D7000 so will not hesitate to get one for my D800
Stan
St Petersburg Russia
Darren Langdon
Are you sure? Do you have one? It sure looks like plastic in the pictures. The Pixel grip has a silver metal pin and the Meike has a black plastic looking pin. can you confirm it is metal?
FCAS Member #104
Mike.
I would be hesitant to assume this would fit the MB-D12 packs... until one is advertised for the specific grip.
Ric
DafO Regular Member • Posts: 294
UK Pixel Grip sellers ?
Anybody know of any UK Pixel sellers ?
Particularly for grips / MB-D12 ?
Have been stung with import VAT + handling fees of late and want to avoid it.
Only seem to find HK sellers on eBay.
 DafO's gear list:DafO's gear list
Nikon D800 Nikon D200 Nikon D70 Fujifilm X-T10 Nikon D850 +10 more
Re: UK Pixel Grip sellers ?
I have never been hit with any extra costs previously from HK. I wonder if it's something to do with the old colony status allowing freer duties . Unless its under a small sum I always get hit from the USA. It could also depend on the weight of the package, a heavy package or large package "must have something valuable in it".
Mike.
Actually - the recent one was from Canada not HK, but I was looking to avoid the risk regardless of country.
Anybody receive new aftermarket D800 Battery Pack Grip yet ?
Would like to see evaluations posted of new aftermarket D800 Battery Pack Grips and hopefully some answers to the many questions asked about them...... Pixel Vertax or Meike or ? .... please post evaluations ASAP.....
