NX20 Freezing (not the lock up issue)
Started Jun 20, 2012 | Discussions
Kaziklu Senior Member • Posts: 1,301
Hi this is my first message here, honestly I avoid this place because well... I've read poor info about many things. However it is one of the few places I can ask this question, and it's one that you folks are usually very good for (as the trolls will stay away)
I recently upgraded to the NX20 from the NX11 (as an aside I told the sales rep the buffer and write times were a concern and I'd be happy to switch systems to a DSLR and he looked at me straight faced and said, you don't need a DLSR this is an excellent camera)
Took it home and started testing it out, getting used to it, going through the settings, playing with video.. getting really annoyed with the slow buffer and write times that I was just told are nothing to worry about... (but the firmware update has made workable.)
However in the last 36 hours the camera has frozen (requiring the battery to be removed) over 12 times. I'm curious if anyone else has had this problem? I've already went in to say.. hey... and a new one is being ordered. I'm just curious if anyone else has had a similar issue, to see if it's common.
As an aside, I'm using a Transcend class 10 Card, which worked will on the NX11, would going to a different card improve performance any (like an extra shot or two before the processing lock up)
 Kaziklu's gear list:Kaziklu's gear list
Samsung NX20 Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 50-200mm F4-5.6 OIS +1 more
Samsung NX11 Samsung NX20
tjobbe
tjobbe Senior Member • Posts: 1,430
Re: NX20 Freezing (not the lock up issue)
I had the freeze issue yesterday myself in playback mode (although it was the first time I did use a third party battery so it might have been related to that as during the first three weeks I never had any issue with that) but I did get reports from another user who had a similar experience as you did have with frozen NX20 that only reacts on battery removal....
I guess we get another Firmware update soon
EDIT: the transcend Class 10 are not really fast compared to some CLASS10 Sandisk ones.
 tjobbe's gear list:tjobbe's gear list
Samsung NX300 Samsung NX30 Samyang 35mm F1.4 AS UMC Samsung NX 85mm F1.4 ED SSA Samsung NX 12-24mm F4-5.6 ED +18 more
Coldamus Senior Member • Posts: 2,281
replied in error, sorry.
question already answered
Vygi Regular Member • Posts: 189
Re: replied in error, sorry.
Mine got frozen several times during preview of a new picture. It happened maybe 5 times in 10 days; in this time I shot almost 1,700 photos and used the 1st stock firmware. SD Card: 32 GB SanDisk Extreme "HD Video" (Class 10).
Alexramos
Alexramos Senior Member • Posts: 1,602
Mine too, it happen using a Minolta lenses. First the camera started to underexposure and then it frozen.
It was with the new firmware.
travelinginthestates.blogspot.com
streetsinblackandwhite.blogspot.com
(unknown member) Veteran Member • Posts: 6,192
Have you done a reset in the menu? Even after a firmware update it might be worth while doing one to clear any rubbish in memory. To be very cautious a reset before and after firmware update would not do any harm and make sure the environment is as clean as possible for the update. You never know what mischief some odd combinations of old parameters not cleared properly and new firmware routines may get up to and what rubbish the firmware update leaves in memory. Ideally it should not matter but.....
viking79
viking79 Forum Pro • Posts: 14,157
I have had a couple lockups too, trying to pin down what causes them. It could be something to do with screen angle and a certain function, or something else. I don't think it is new firmware specific.
As suggested. Format your memory card in camera (make sure you have all your pictures saved) and do the reset in the menu to reset all the camera settings and see if that makes any difference.
I am trying to nail down more what causes the issue to see if I can recreate it (very hard to fix software/firmware problems without being able to recreate the issue). Try to keep notes of what you were doing when it locked up.
Eric
I never saw an ugly thing in my life: for let the form of an object
be what it may - light, shade, and perspective will always make it
beautiful. - John Constable (quote)
See my Blog at: http://www.erphotoreview.com/ (bi-weekly)
Flickr Photostream: http://www.flickr.com/photos/28177041@N03/ (updated daily)
Sony a7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
OP Kaziklu Senior Member • Posts: 1,301
Well I'm using all the base kit, it's happened with both the original and updated firmware. It's happened while shooting in RAW and JPEG, Continuous shooting and single shot, and Movie mode, both at 1/4 speed and standard 1080P. Happened indoors and out, In Aperture Priority, Manual, and SCN mode. It's happened while processing, in the middle of shooting, and as the shutter closed. It's also happened in Manual Focus and Autofocus. With the First Gen 50-200, and the kit 18-55
I have Electronic Shutter turned of, DMF on. Though it happened before I found and turned on DMF. It's also occurred with preview turned on or off, and while using the EVF or the screen in multiple positions.
It started happening with in the first hour of camera operation out of the box.
I'll try a reset if that helps.
If I keep it, which looks unlikely based on these comments. I will try a different card.
In it's current state it's totally unreliable, and the buffer issue is enough to say this may be the worse camera I could have gotten. My NX11 went everywhere I loved it... my only complaint was the noise levels. This solves that for the most part but it's unpleasant to use.
Nope lock up continues... this time I got the most shots between lock ups though. At about 40.
I think I'm just taking it back...
I would be much more patient if the Sales Rep hadn't stood there and bold face lied about the Camera being great after I mentioned I have serious concerns about the buffer and write speeds. They better still have my NX11.
Molfious Forum Member • Posts: 51
Most likely your memory card is causing this. I had the issue, but switched cards and it is a lot better now. Only locks up 1 out of about 1,000 shots. Pretty sure this is a firmware issue that will be fixed in the next release. You may also want to ensure there is no dust in your battery / card slot compartment as this can cause this type of problem as well.
Well based on further testing and more shooting, I've thought about it being the card, but of course the issue didn't happen on the NX11 ever... never once had this issue in a year. But I do plan on putting a new card in it to see, if only for performance. The battery is getting hot though, really hot. Like the inside of the battery casing is very hot.. and when it freezes if you let it sit the whole camera gets so hot in about 15 minutes it feels like it's been in an oven.
I'm fairly sure it's a defective battery or a lose connector some place.
I've come to the conclusion the first run of the NX20 had some quality control issues.
I'm glad that I'm not the only one that has thought about the Card though... the store staff whom I'd assumed they would say just that, looked at it like the opening scene of 2001
viking79
My NX11 locked up all the time, buffer would crap out and I would lose everything in the buffer. It hasn't done it recently though.
It does sound like yours might have an issue though. I wouldn't expect that many lockups. I would still try a different memory card though. I have seen a compact flash device that would cause a kernel panic when a certain brand and type of CF card was inserted.
As for the battery thing, my camera does slow down a bit when the battery gets to red. I can't take a shot while it is writing to the memory card, etc. Like it is trying to conserve power and doesn't do as much at once. So I wouldn't be surprised to see battery related issues. Try the battery from your NX11 and see if it works any better, or return your camera and swap it for a different unit.
Eric
That is why I recommended that you ensure you battery compartment is clean of dust and other items as that can cause the problem you are talking about. For clarity, my camera was never hot when it locked up and I too had an NX11 that nerver locked up.
Ya I've actually done all that.. got my Warhammer painting light and magnifier out too (it's black and on black, the the Memory card slot is small and in a bad spot. Gave a bit of a Qball blow upside down too, just in case.
Haven't had an issue in about 24 hours.. however I also haven't kept it on in between testing, to keep the battery from heating up too much.
I've noticed each time it's happened that batter has been warm, which is what lead me to the conclusion that it was a connector or battery issue. It's also possible because the battery is right next to a metal plate which the SD card goes in, which gets hot not warm to the touch, that it may be heating up the card beyond it's operating capabilities. (the card location seems dumb anyway). We will see I'm going to pick up a new card tonight, see if I can find a SanDisk with more then 20mb/s write speed so I know it can max out. I'd just go back to the location I bought it, but I'll go down to staples instead the staff at the store is... ummm not inspiring confidence.
Thanks for the help folks. Figured if I was going to get an answer this is the place to get it.
Ok, I have done some testing to figure out why some users are reporting much faster performance and no lock-ups post firmware 1.0 update. For clarity this is the minor revision firmware that shares the same version number as the production release firmware, what many are calling version 1.01.
1. Ensure you reset your camera to defaults.
2. Format your memory card.
3. Copy the rom and bin files to the root of your memory card.
4. Flash your firmware.
5. Reset your camera to defaults.
6. Format your memory card.
I have tested this and can report much faster shot to shot performance in RAW, RAW + JPEG with no waiting between shots. About 50% faster performance overall. I haven't had a single lock-up since I have performed these steps in this sequence as well.
Let me know if this works for you.
I think all this battery talk and clean card slot is the sort of red herrings that companies put out when they know the real problem but cannot admit it and like to make the customer think they are doing something wrong. The problem is probably poor firmware testing and it is just full of bugs. The fact that the new version has the same version number really shows the quality control standards being applied. I think these firmware updates are just code and release, I doubt if there is much rigorous testing going on. Samsung made their fortune selling disposable goods so keeping a continuous product line going is bound to be a steep learning curve for them and they may not be up to it. I think being in NX you have to accept that you are in a bit of an experiment which might not work in the end. Just because a corporation says it is going to carry out a plan does not mean that it will or can do this. Samsung are already way behind the market penetration thet promised in the earlier stages of NX.
For all Samsung's wealth the budgets in the NX project may be very tight and there may not be a buy in at all levels of the organisation that the project is viable or worthwhile. The rumoured cancellation of the 16-80 shows that all may not be well and all this nonsense about waiting 3 months for an announcement at a trade fair seems to be a bit of playing for time to cover up internal confusion about direction and lack of any real news. How many expected EX2 announcements have been and gone. Samsung are looking to me a bit like a fish out of the water in the system camera world.
I think in this case it is simply a user community trying to help each other out with a similar problem they have been experiencing. As for pontificating about various vendors and their support models, you can find flaws in almost all of them. But in the end, you simply need to enjoy the platform(s) you have invested in and start taking photos.
The NX11 is the first camera I have had for a long time that I am worried about selling on eBay because of its erratic behaviour after a firmware update. I will most probably trade it in which will cost money. I think we should not play down these problems as 'all manfufacturesr have them'. I think DPR is pretty good for getting an idea of where products flaws are and I think firmware is Samsung's weak spot. I am not sure blowing out the SD card slot really helps what is a problem Samsung's cameras appear to have reading different makes of SD cards. The problem appears to be that if you have the wrong card in it is difficult to take photos and only pressure on Samsung will cure this. I gave in and started using a Samsung card but this will not be fast enough for a lot of users.
I find that interesting, as I had an NX11 for a long time and it was trouble free? I got top dollar for mine when I sold it online, but to each their own. I can give you many examples of issues that cross almost every major camera manufacture if you care, but simply go do some research on your own and you will see what I mean.
Here are some examples though:
1. Fuji x100 & x10 - firmware issues at launch on onward. After all their efforts Fuji continued to screw this up introducing new bugs in successive launches of firmware.
2. Sony NEX 5n and NEX 7 - manufacture defect (NEX 5n) causing clicking noise in all cameras launched within the first couple of months. Not sure this was ever fixed. Bad kit lenses on NEX 7 and firmware issues that have still not been fixed.
3. Nikon D800 and Canon MKIII - top end cameras with firmware issues at launch that still have issues that need to be fixed. Canon admits exposure errors and light leaks while Nikon defends green screen issues and confirms focus / viewfinder issues.
4. Samsung NX200/20 - slow processing times in launch firmware - unnecessarily large RAW files. Still confused as to why the RAW files are so large given the sensor size.
That said, I have enjoy the Fuji x100, NEX 5n and NX20 even with these flaws as they all offer different excellent functionality in their respective areas.
