Owning a WB850F, my thoughts
Started Jun 9, 2012 | Discussions
peewit Junior Member • Posts: 27
I have owned a WB850F for a month now.
My needs:-
A travel zoom with a GPS tagging feature.
Basically I want a camera that is small so that I always have it with me when out of the house.
I want a good zoom lens and a decent quality image.
In my opinion the WB850F is not for the serious photographer where a DSLR brick and a set of lenses is needed.
For this reason I am not posting photos taken with the camera. They meet my needs from a travel zoom.
I do have a Canon EOS DSLR kit for these situations but it is not possible to always have it with you.
A bit of history.
I have owned a previous Samsung travel zoom for a couple of years now (the WB650) and been happy with it's performance while accepting some limitations.
With the WB650 you have a x15 optical zoom with 24mm at its wide setting and 12 megapixels with GPS tagging. Typical jpg file sizes are 2.65MB.
I found that with this camera the picture quality met my needs. I could have done with a longer zoom. The GPS tagging was tediously slow. I would be standing in Sydney harbour waiting to take my planned shot. Minutes would go by, the boats would change position, a cloud would cover the sun, etc. I often took a shot with no GPS lock and then maybe another later when eventually GPS was attained. Even when having got a GPS signal, if you turned off the camera and then turned it on again a few minutes later and in roughly the same location it could still take 30 seconds to get a fix.
The Intelli-studio PC software was never used as I could not make it store my photos where I wanted.
I remove the SD card, plug it into my PC to copy and paste the photo files to my chosen location.
The new WB850F
The spec. for this camera looks good with a x21 optical zoom with 23mm at its wide setting and 16.2 megapixels with GPS tagging and a wifi capability.
So I thought that with two years elapsed time that Samsung would have made some significant improvements.
I decided to purchase one.
Typical jpg file size is now over 6MB.
I have not taken that many photos due to operational problems.
My main issue has been the camera battery going from fully charged to flat in just a few days, even with the camera switched off. This does not happen with my WB650 camera.
My experience of speaking to Samsung support is that they tell you that it is normal for a battery to go flat in that time.
They are unaware of the correct led light sequence when charging the battery in the camera. So I suspect you are not actually get any help by speaking to Samsung support. It seems that whatever issue you have is regarded as normal.
Samsung have been issuing new firmware for this camera. The firmware updates do not come with much in the way of information on what problem they are addressing. The last firmware update that I tried using the suggested procedure with Intelli-studio failed and the update was withdrawn after a couple of days.
GPS. Well it does not seem any better than with my WB650 and still takes a long time to get a fix. When I use the built in map it even shows the photo taken in a different location to where I actually took it. However, once you get the photo on the PC it seems to correctly locate the photo. Getting a GPS tagged grab shot is not going to work unless the camera is already on and in GPS lock.
Wifi. This is very flaky and almost useless. I have had multiple problems with it. Even when it works, as the files are 6MB in size it is very slow to transfer data on a decent speed home wifi network. Using a wifi hotspot must be a nightmare.
About the only thing it seems to manage well is sending a photo by email to someone where it shrinks the photo file.
If you try to backup photos to cloud using Skydrive do not be fooled by the browser screen where you can select to save your email details and password. Doing this will crash the software. It will work if you tediously key in the entire details on each use.
So summarising my experience of the WB850F so far :-
1) Long lens and better resolution are good.
2) Intelli-studio will not save files where I want and I will not be using it.
3) Wifi is flaky and I will not use.
4) GPS is still slow to get a fix so you need a static scene and patience.
5) Samsung support have not given me any actual usefull information.
6) Battery drain problem
7) Other issues that I will not bore you with.
Maybe the battery issue is being or has been fixed in firmware updates.
Patience is a virtue.
Peewit
Leica X2 Olympus FE-20 (C-25 / X-15) Samsung HZ35W (WB650) Samsung WB850F
(unknown member) Veteran Member • Posts: 6,192
Re: Owning a WB850F, my thoughts
A very comprehensive analysis. Sorry to hear you are finding things a struggle. You should not need patience though. How your average Joe on the street is going to cope with this I do not know. You have to wonder what field testing if any has been done on the camera with its production software firmware installed. They must stop beta testing the stuff with early take up buyers in the rush to get to market. Samsung really need to put a chunk of money into goodwill or their reputation with the photographic community will go farther down the toilet than it already is.
Sorry I am sounding like steakb. I will sign off for the day until I get better but it is depressing sometimes just looking at the way Samsung work. They do make money but a bit of Sony's customer orientation, though extravagant, would be nice occasionally.
I was tempted to switch my lumpy but reliable with long battery life Canon SX40 to a WB850 but that idea has completely evaporated.
swhs Regular Member • Posts: 113
Customer orientation by Sony? In lots of cases they treat customers like a POS.
But I agree about the beta testing. It is however not new, and cameras getting complicated software wise make the same practices from there (software development) come to cameras. It's not just Samsung
A very similar phenomenon was taking place in other fields already in the late 1980s, where a dealer told, about failures of televisions, that none are tested in the factory, as just letting the customer find out about problems, then fixing that TV, is cheaper than testing each TV for faults!
I'm not sure how much such concepts are applied in the production of cameras, causing a lot of individual camera failures that would have been found out with proper testing. Insider info is welcome!
Lutz24 New Member • Posts: 5
While being only an occasional hobby photographer, I do understand your point. I know from my experience as developer in a different but related field that the complex management structure of a very large company ironically often dooes not allow for common sense towards their customers. Software releases are usually rushed in with significant problems remaining. Marketing agenda's have seldom anything to do with the actual quality of the product and satifaction of the buyer, which is sad. Product and project managers are usually geared to meet deadlines that are often set way too short by their superiors. The blame cannot be placed onto the developer, who often works more that 12 hours a day on multiple projects and is seldom given enough time to really finish. If something takes too long, to meet the "bottom line", the upper management usually decides to abandon the problem - to either discontinue or in some cases to outsource which is even worse. Although there are exceptions, but smaller companies, who do not have this problem seldom make it very far. Understanding this, makes it very hard to buy anything these days.
Anyhow, I am probably not as much disappointed as you are, but the root cause of dissatisfaction that you describe can be found in pretty much all trades of life.
I was thinking more of Sony's presentation of goods. I am sure they can make the life of a customer who is trying to get something fixed a misery as well as the rest. I have always found Sony stuff very reliable, my A200 never had a firmware update, there never was one made available but it functioned perfectly and I could use an ancient Minolta lens on it fully automatically, no software problems. The camera industry is most probably in a bit of a melt down at the moment with too many companies making too many types of lens mounts (with CSC can be 2 per manufacturer making the market increasingly thin) and increasingly complex operating software in the cameras and now the lenses (Samsung has 2 suites of lens firmware) and at the same time phones are making inroads on the whole industry all the time. All this in a time of growing austerity in the Western economies. Something must break soon
I do wonder what anguish and confusion lies behind the bland exterior of these large corporations. I should think the meetings in Canon on what to do about mirrorless cameras would be pretty entertaining, a great pity all this drama is so secret.
OP peewit Junior Member • Posts: 27
I have to say that the mechanics and optics on the WB850F do seem very good and are just let down by the poor firmware/software.
The lens on the WB650 did also seem good except that I did have it replaced under warranty about two weeks before the 12 months was up. It had the problem with the stuck lens cover that others seem to be currently experiencing.
It is interesting to read the comments about conflict between marketing and development depts. in large companies. Beta testing can not have happened on the WB850F as the problems are hard to miss.
Peewit
jj74e Senior Member • Posts: 1,633
A nice analysis, agreed; it's a bit unfortunate how many problems you are having. Sony's new travelzooms seem very competent; perhaps you should take a look at those if you can return your samsung.
It seems many peoples' fears, including my own, about Samsung's wi-fi implementation, are becoming true, that they are very gimmicky/marketing hype than actually useful in execution. It's weird how samsung can be so competent with their appliances, TVs, smartphones, even laptops, yet their camera division suffers. when people say samsung isn't a photographer's company, i just think that they are a hugely successful electronics company in a time when so many others are losing profit. but the weird thing is, the photographic things like their sensor, UI, lenses, external controls, are good, but it's the electronic stuff they're failing at- write speeds, GPS, wi-fi, etc.
Not at all. The problems people are having with the WB850F is definitely a reasonable cause for your worries about Samsung. steakb would just be ranting and making personal attacks.
Lucky you had the problem before the warranty was up. Stuck lens covers seem to be a general problem with all makes.
Peewit
Cyril Catt Veteran Member • Posts: 5,453
Thank you, peewit, for the detailed summary of your WB850F. It seems that the older technology of photography works reasonably well, but the newer technology which depends on wireless communication is less reliable. Other makers are also not having perfect results with their wireless features, and I wonder if these aspects are still not sufficiently worked out to be dependable.
Cyril
 Cyril Catt's gear list:Cyril Catt's gear list
Canon PowerShot TX1 Panasonic Lumix DMC-LX7 Apple iPhone 13 Pro Max +3 more
thielges
thielges Contributing Member • Posts: 661
GPS lock time
Thanks for taking the time to summarize your experience. I am surprised about the long time to get a GPS lock that you experienced with both cameras. My WB650 will reliably lock within 45 seconds from a completely cold start (i.e. hasn't been turned on for days). The trick seems to be to turn the camera on and set it down somewhere with a wide view of the sky. Resist the temptation to hold the camera while it is locking. Either the proximity to your body or small hand movements (or both) seem to interfere with its ability to get a quick lock.
Re: GPS lock time
Hi thielges
Thanks for the tip. I will certainly give it a try when circumstances allow. I was trying to use my travel zoom in a spontaneous way, where I was not thinking about photography all of the time. I certainly got the 45 seconds lock time sometimes however if there were trees or buildings in the vicinity it could take much longer or not work. My ageing iPhone 3GS would always get a GPS fix far faster and in poor situations such as being on a bus as it drives through a city of tall buildings.
My hope was that with the elapsed time since the WB650 came out, that the GPS sensor in the WB850F would have been improved to what seems to be the current standard on other devices. It was a let down to find the same slow response and lack of sensitivity.
Peewit
Coldamus Senior Member • Posts: 2,281
Re: GPS lock time
peewit wrote:
Hi thielges
The reason GPS in a phone is faster is because it can use A-GPS (assisted gps). Providing that in a camera would require a phone account for the camera and would incur charges. A-GPS downloads some of the data required for the initial fix from an assistance server on the telecommunication provider's network. More details here: http://en.wikipedia.org/wiki/Assisted_GPS
Re: GPS lock time
My iPad2 seems pretty quick and sensitive to locate a position and I have not got a sim in it and hence no access to the cellphone network. However I take your point.
Peewit
thielges
wifi can also be used to speed up GPS lock time
If I were to design a wifi+gps enabled device like an ipad I'd exploit the fact that wifi base stations are usually stationary and can provide a clue to the current location, speeding up GPS lock time. Plus you could also implement some of the A-GPS techniques like downloading the current satellite ephemeris over wifi to further speed up GPS locks.
While the WB850 has wifi I'm not sure Samsung has implemented any A-GPS style techniques.
Re: wifi can also be used to speed up GPS lock time
There are some iPad2 apps for pilots of small aircraft where they are used to provide a moving map display of aircraft position using GPS. Wifi and cellular networks are not going to be of much help for an aircraft doing 100 knots at 4000ft agl.
My Memory Map app is useful for position location and tracking on the ground.
Maybe the restrictions of the WB850F housing contribute to its underwhelming GPS performance.
Peewit
thielges
I didn't that wifi is required to use GPS, just that it can accelerate the initial lock time. Most pilots don't just jump in the aircraft and fly off. They usually spend at least several minutes on the preflight check which is plenty of time to get a cold lock even without wifi or any other A-GPS techniques.
Your right. Maybe I just need to accept that fact that the GPS performance of the WB850F has not improved in the two years elapsed time since I got the WB650.
Disappointed.
The iPad2 with its big battery and large case is bound to be in another class.
Peewit
thielges
True though I don't know of any handheld GPS devices without wireless that lock quicker. It could be an inherent limitation of the technology. The only GPS devices I know that lock quicker are either using A-GPS or the initial position trick that automotive GPS units use. Samsung could use the trick that the iPad uses via wifi though I would not count on a firmware upgrade given past history.
I'm going to get a handheld GPS+GLONASS receiver soon so it should be interesting to see whether the addition of GLONASS improves lock times.
