Hoya CPL - rotate ring and oil?
Started Jun 8, 2012 | Discussions
b4cktr4ck Regular Member • Posts: 161
Hiya,
I just got a HOYA PRO1 CPL 67mm.
I have noticed that it has a rotating ring. (on the half part where the thread to screw on the lens is)
what is that for?
also there came out something that looks like oil from the middle, that has now stained the external part of the filter
 b4cktr4ck's gear list:b4cktr4ck's gear list
Canon EOS 6D
sillyconguru Veteran Member • Posts: 3,057
Re: Hoya CPL - rotate ring and oil?
b4cktr4ck wrote:
I have noticed that it has a rotating ring. (on the half part where the thread to screw on the lens is) what is that for?
It is so that you can rotate the filter to achieve the desired effect.
That'll be the lubricant used to ensure smooth rotation
 sillyconguru's gear list:sillyconguru's gear list
Casio QV-5500SX Pentax Optio I-10 Fujifilm FinePix X100 Canon ELPH 100 HS Fujifilm X20 +54 more
Ben O Connor
Ben O Connor Contributing Member • Posts: 981
Check my latest threat on olypus talk about XZ-1 with Hoya PL-CR filter also. Gives some ides i suppose...
 Ben O Connor's gear list:Ben O Connor's gear list
Olympus XZ-1 Panasonic Lumix DMC-GM1 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Panasonic Leica DG Summilux 15mm F1.7 ASPH +4 more
