stuck lens cover HZ35W WB650
Started Jun 4, 2012 | Discussions
thielges
thielges Contributing Member • Posts: 661
The four bladed automatic lens cover on my HZ35W seems to be gummed up and jams both opening and closing. When switched on the lens cover doesn't entirely retract, leaving a diagonal vignette. When switched off the lens cover sometimes stays open.
Does anyone know how to disassemble this part of the lens? I have a hunch that it requires a deep disassembly of the camera but if there's an easy solution then I might be able to get in there and clean up and lubricate.
For now my workaround is rapping the camera on something hard to dislodge the lens cover. That doesn't seem appropriate for a sensitive optical instrument
Samsung HZ35W (WB650)
Brad99 Veteran Member • Posts: 3,145
Re: stuck lens cover HZ35W WB650
No idea how to disassemble unfortunately, but my WB650 blades open easily by hand with the camera off and are sprung loaded. Therefore I guess the problem is either...
1. Dirt, crud in the works.
2. Bent blades from a knock.
3. Broken spring.
No. 3 you should be able to feel for.
No.2 you may be lucky and be able to straighten without disassembly as they would likely be bent inwards and could be pulled out, but there's the risk of breakage.
No.1 if it were mine I would try a tiny amount of WD40 dribbled in, but that's me and I wouldn't recommend it to anyone else.
MikeGF Regular Member • Posts: 326
I would expect this to be grit in the blades. You could try turning the camera on and off several times and helping the blades open and shut with a toothpick or match stick. With luck this may dislodge the grit.
WD40 may work but I would worry about it getting on the lens.
On the Panasonic forum someone had a similar problem and ended up putting a very small spot of super glue on the blades and then leaving them open.
This did mean the blades were fixed in the open position but it didn't affect the operation of the camera.
I hope you manage to fix your camera and do let us know how the outcome.
Mike
Mike
Mike
Sorry about posting the same reply three times but the DPR site went into meltdown just as I pressed the 'post' button.
Mike
thielges
OP thielges Contributing Member • Posts: 661
Thanks for the responses. So far I've tried "washing" the mechanism by daubing on small quantities of water, open/close cycle, then drying off what remains. That got the cover to close reliably. It still sticks at about 70% open when opening though.
I recall that there was a blob of water soluble gunk on one of the lens cover leaves a while back which I had carefully wiped off. So my suspicion is that some of that gunk got into the mechanism before cleaning.
I wish I could just disassemble the outermost piece of the telescoping barrel. I'm sure a nice cleaning would do the trick but that is difficult to do from the outside. At worst case I'll just glue the lens cover shutter open but then I'll need another way to protect the lens when packed away.
Pugwash69
Pugwash69 New Member • Posts: 16
lube
Don't use WD-40, it'll atrract dust forever afterwards. The spray of choice on another forum I use is ACF-50. I also keep a can of compressed air - useful on computers and all sorts.
 Pugwash69's gear list:Pugwash69's gear list
Samsung NX11 Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 50-200mm F4-5.6 OIS +2 more
skydivepete New Member • Posts: 1
Hi I took a tumble down a muddy hill with my lens open on my Samsung PL170 and tried all sorts to free the stuck lens,
a combination of the paper trick  and the hoover advised in this forum worked so many thanks for the help, saved me a fortune
