Extender/Teleconverter
Started May 28, 2012 | Discussions
RaleighSenior New Member • Posts: 1
I'd like to add an extender/teleconverter between my Canon EOS 500 (Rebel T1i) and Canon EF-S 55-250mm lens. Is there a 1.4x or 2.0x extender/teleconverter which will fit and retain the autofocus and image stabilization features?
Canon EOS 500D (EOS Rebel T1i / EOS Kiss X3)
Y0GI Veteran Member • Posts: 5,253
Re: Extender/Teleconverter
Unfortunately, not. There are some that you can mount on the front of the lens, but I wouldn't do it, because of the weight of the TC hanging off the front barrel of the lens which moves during focusing/zooming: http://raynox.co.jp/english/dcr/dcr2025pro/index.htm
http://www.bhphotovideo.com/c/product/381969-REG/Canon_0300B001_TC_DC58B_1_5x_Teleconverter_Lens.html#specifications
Yogi
When you get down to the nuts and bolts of photography, the results depend on the 'nut' behind the camera!
See the 'Gear List' in my 'Profile' for my current equipment.
Check out WilbaW's beginner FAQs at - http://snipurl.com/RebelFAQ
 Y0GI's gear list:Y0GI's gear list
Canon EOS 7D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100-400mm f/4.5-5.6L IS USM +2 more
Tony82 Junior Member • Posts: 35
Don't canon do extenders to fit eos cameras, say something like a 2 x extender will make a 75-300 to a 150-600 not sure if you will retain you autofocus
search ebay or google for canon extenders
http://www.ebay.co.uk/itm/Canon-Extender-EF-2x-II-Teleconverter-/221030605205?pt=UK_Lenses_Filters_Lenses&hash=item3376736195#ht_500wt_1287
did a quick ebay search and found a few, the link above is just 1 hope that is waht your looking for.
Lemming51
Lemming51 Forum Pro • Posts: 15,261
No. Canon's own tele-extenders (EF 1.4x and EF 2x, original, Mk I, II, or III) fit only a select few L series primes (135mm and longer) and L zooms (70-200 f/2.8 and f/4L and 100-400). They have an extended front element that fits into open space at the rear of these lenses. Other lenses don't have that open space at the rear.
Teleconverters by Kenko, Tamron, etc. made for the EF mount cannot be mounted to EF-S lenses like the EF-S 55-250. EF-S lenses have a bit of extension back from the mount that prohibit them being mounted to these converters.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
WilbaW
WilbaW Forum Pro • Posts: 11,619
A TC and an EF-S lens can be combined by putting an extension tube between them, but that means you can't focus in the distance.
Check out the unofficial Rebel forum FAQ - http://snipurl.com/RebelFAQ
 WilbaW's gear list:WilbaW's gear list
Canon EOS 60D Canon EOS 7D Mark II
Narcosynthesis Senior Member • Posts: 1,832
There are 1.4x and 2x teleconverters made by Canon (and indeed third parties) but they are not really designed to work on a basic lens like the 55-250mm.
The main problem is that when you add an extender, you effectively narrow your aperture - losing one stop of light on a 1.4x, and 2 stops of light on a 2x converter.
This is fine when you are looking at a fast high end prime like a 300mm f2.8 and a high end body that can focus at slower apertures, but attempting to use it with a more basic model will just test the system too much and you will be left with poor (if at all) AF and a very slow lens.
You do sometimes see cheap add on lenses to go on the front of a lens to get more reach, but in general I would avoid these as poor quality.
Sadly the only option to get more reach is to save up for on of the bigger lenses - check out the third party options from the likes of Tamron and Sigma for a slightly less pricy entry into the super telephoto lenses.
http://www.flickr.com/photos/narcosynthesis
http://www.illaname.deviantart.com
