600d thumbwheel not working.
Started May 25, 2012 | Discussions
YSrcflyer Forum Member • Posts: 63
In the last two weeks I had my thumbwheel not respond in Tv or Av mode twice. After getting home from the races I attended I tried it and it worked both times. I left the camera on at home for over three hrs last night thinking maybe it was getting warm and causing the problem. So far it has been working perfectly. Has anyone else had this happen?
 YSrcflyer's gear list:YSrcflyer's gear list
Canon EOS 70D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 60mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon Extender EF 1.4x III +4 more
Canon EOS 600D (EOS Rebel T3i / EOS Kiss X5)
Lemming51
Lemming51 Forum Pro • Posts: 15,278
at the risk of being obvious ...
This is typically the result of inadvertently locking the wheel, as described on p. 42 of the 60D manual.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
Y0GI Veteran Member • Posts: 5,257
Re: at the risk of being obvious ...
Lemming51 - Your advice is spot on for the 60D. However, the title of this thread states that the camera in question is a 600D, which does not have a "Thumbwheel", only the Main Dial and Cross Keys, so this post is a little confusing as to what is the camera and what is the problem?
YSrcflyer - Which camera do you have: 60D or 600D? Did you mean to say that the problem is with the "Main Dial" on a 600D?
Yogi
When you get down to the nuts and bolts of photography, the results depend on the 'nut' behind the camera!
See the 'Gear List' in my 'Profile' for my current equipment.
Check out WilbaW's beginner FAQs at - http://snipurl.com/RebelFAQ
 Y0GI's gear list:Y0GI's gear list
Canon EOS 7D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100-400mm f/4.5-5.6L IS USM +2 more
OP YSrcflyer Forum Member • Posts: 63
Sorry, yes the main dial, right next to the shutter button on an 600d/t3i.
Denelle
Denelle New Member • Posts: 3
Hi Everyone.
I have a the same camera 600D - T3i
I have experienced the same issue just yesterday, i can no longer use the dial.
I have to used the Dpad on the back to change my settings.
Denelle
Re: 600d thumbwheel not working.
Ok, here is an update for anyone who has the same issue.
I tried to update the firmware but that did nothing, then i left it off with the battery and lens apart from the camera over night and just tested it and it seems its working again, i suppose what you should do is simple walk away from it for a bit. Take the time to clean your lens or sort out your gear.
Anyways that work for me so far. I will of course update this post if the situation changes
Cheers
Denelle
Thanasosdk Regular Member • Posts: 100
Any chance there is a grip on the camera?
If so, maybe the main dial on the grip is not in possision(between spots).
Happens to my 550d/t2i more than enough times.
Thomas.
 Thanasosdk's gear list:Thanasosdk's gear list
Canon PowerShot A710 IS Canon EOS 550D Canon EF-S 18-55mm f/3.5-5.6 IS Canon EF-S 55-250mm f/4-5.6 IS II +2 more
BAK Forum Pro • Posts: 26,020
How mine got fixed
A few weeks ago my T1i front wheel stopped doing anything.
I took it to a local repair shop and a few days later got a call saying it was a circuit board problem and would cost $200 to fix, and take a five days.
Fewer than five days after that he called saying the repair was done. Final invoice was around $175.
Repair shop is on Lakeshore Road in Port Credit, outside Toronto.
BAK
karl mohr Senior Member • Posts: 1,678
Can't say I've had this problem, but - occasionally my T3i becomes unresponsive, like something's wrong, etc.  The last time it did this I was swapping lenses out in the field.  I thought it had died after that.  Took the battery out for a minute and everything was ok at that point??  My T2i and T4i don't seem to have that issue.
 karl mohr's gear list:karl mohr's gear list
Canon 6D Mark II Canon EOS 60D Canon EOS 80D Canon EF 17-40mm f/4.0L USM Canon EF-S 55-250mm f/4-5.6 IS +3 more
I have found out if I remove the battery for a few minutes and then reinsert it, the wheel will start working again. Have been doing this since the first post-seems like the software "locks up"? Have been able to regain use every time after removing battery for a couple of minutes.
Maybe the T3i has some 'buggy' software.  My T2i and T4i have not really become unresponsive like the T3i.
fatmatt New Member • Posts: 1
Had same issue today with my 'kiss X5' version after attaching ext tubes to it,
it has a cheap 3rd party hong-kong grip too, came on here to see if any advice and best seemed to be to clear ALL camera settings then remove card,then lens, then grip, then batteries then put it all back together again!
Hey presto! All good!
worked for me,
hope it does for you!?
tonysmarx New Member • Posts: 1
This totally fixed the issue for me. The grip dial was in between spots clicks. Whew.  Thanks!!
