A900 flowers with distagon
Started May 20, 2012 | Discussions
Guido FORRIER Senior Member • Posts: 1,723
simple test to show how the A900 with distagon 25mm 2,8 (non Sony) renders the colors .
i bought the lens mainly for landscape but close ups are also very nice .
guido
Bart7D
Bart7D Veteran Member • Posts: 4,432
Re: A900 flowers with distagon
Fine details, subtle colors - basis for some fine art...
Thanks for sharing, Guido!
Bart
 Bart7D's gear list:Bart7D's gear list
Konica Minolta Maxxum 7D Sony Alpha DSLR-A700 Sony SLT-A77 Sony Alpha a99 Sony a77 II +21 more
OP Guido FORRIER Senior Member • Posts: 1,723
dank je wel Bart .
as you see the A900 is still a capable camera if used with nice optics and good software . I used here Raw Photo processor 64 .
guido
LesP Contributing Member • Posts: 881
I openned this in work, with bog-standard IE8 on a 'basic' Dell VDU.
It appeared 'flat', 'soft' and uninteresting. Too 'subtle'...
I opened at home on decent kit and wow! what a difference.
Beautiful image
LesP
thanks lesp,
this is the problem when showing photo's on the internet : what kind of browser and hardware are people using ? so you can see clearly how better your computer system is .
kindly,
guido
klensch8844 New Member • Posts: 8
Hello,
I assume you used an M42 Distagon? If so, which adapter do you use? Also, did you change focusing screens in the A900?
Thanks a lot in advance.
G.
 klensch8844's gear list:klensch8844's gear list
Leica M Typ 240 Nikon D810 Nikon D500 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 24-70mm f/2.8G ED +17 more
moimoi
moimoi Veteran Member • Posts: 4,247
Hello,
As far as I am concerned, the setting, background and color are not interesting. As far as the colors are concerned, use sRGB as color space (for internet preview). It looks like no color space was selected properly when saved!
Hope this helps,
moimoi
 moimoi's gear list:moimoi's gear list
Fujifilm X100T Canon EOS 6D Canon EOS 5D Mark IV Canon EF 70-200mm F2.8L IS II USM Canon EF 16-35mm F4L IS USM +5 more
osu
osu Regular Member • Posts: 318
Bart
Indeed it does...
 osu's gear list:osu's gear list
Konica Minolta Maxxum 7D Sony Alpha DSLR-A100 Sony Alpha DSLR-A700 Sony SLT-A77 Sony a99 II +14 more
GuyMcKie Contributing Member • Posts: 615
It has a yellow-orange cast on a calibrated monitor and is to soft.
On a uncalibrated display, often to hard in contrast and to cool in color, it wil display better.
Check the colors (white, gray or black) with the color pipet in PS, and save for the web with sRGB color profile.
Regards
hello klensch8844,
yes it is the M42 version with a cheap adapter from ebay and no additional chip . i did not change the focus screen .
it is interesting to see how some browsers and computers alter the colors . i use apple's safari and that browser has no problem showing AdobeRGB .
see the answers of Bart7D and LesP .
my screen is calibrated.
microsoft's internet browser is far behind Safari and Firefox .
to avoid the browsers you can download the photo here :
http://dl.dropbox.com/u/608762/bloemdistagon.jpgx
delete the x in jpgx
can you tell me if this is an improvement .
guido
Ralf B
Ralf B Veteran Member • Posts: 8,209
Hello, Guido,
guido
I downloaded your jpeg and find it lacks contrast. Is there a glass element in that M42 adapter?
Here is a version with bumped up contrast:
Before:
After:
 Ralf B's gear list:Ralf B's gear list
Sony Alpha DSLR-A900 Sony Alpha DSLR-A700 Sony SLT-A55 Sony Alpha a99 Sony 16-35mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* +14 more
i converted the photo to srgb for web :
sorry but this has nothing to do with the original : bah !
greetings,
guido
Re: Hello, Guido,
good evening ralf ,
first of all : how is the look with your browser ?
i did intentional not push the contrast to show how the camera can register fine detail and fine shades .
for print : i should also ad more punch . no there is no glass element .
Guten Abend ,
guido
Ralf B
Re: Hello, Guido,
good evening ralf ,
Safari 5.1.7, looks identical to what I see in Aperture. So no browser problem here.
I just looked at the sRGB large version you posted below, which shows the potential of your cam/lens combo much better. WRT the colors, that sRGB version looks very much like your previous version after I changed WB to "cooler". I did not post that version.
Guten Abend ,
guido
Gute Nacht!
Ralf
http://www.ralfralph.smugmug.com
Re: Hello, Guido,
This with adjusting white, black and background to neutral. The colors seems more pure fore me now.
Reposted it converted to sRGB.
Re: Hello, Guido,
colors ar more fresh now !
my intention was not the accurate color but :
  • show how you can use the distagon 25mm 2,8 in M42 mount for close-up as the minimum distance between the front lesn and the object = 6 cm !
  • i saw the flowers in an dim evening light and i liked to hold the "mood" and not showing the flowers as they were in bright daylight or in studio . for that purpose i have a small studio with multiblitz strobes . as it is shot in raw there is no problem to change the "mood" .
about rgb : why throwing away a lot of colors with srgb as now today screens and printers can handle larger gamuts ?
an other version of the same photo here :
delete the x :
http://dl.dropbox.com/u/608762/_DSC2752RPP.jpgx
kindly,
guido
Re: Hello, Guido,
i show later an other version but i have to leave now
guido
