Frequency Separation --apply image work around for Elements
Started May 18, 2012 | Discussions
gwlaw99 Senior Member • Posts: 1,113
I have been trying to learn more advanced retouching techniques and really wanted to use the "frequency separation" in Elements. Frequency separation (more or less) separates color and texture into different layers. So for example, if you want to clone a texture from area to another, the clone stamp would normally also clone the color. Using frequency separation you can clone the texture without cloning color. You can also color correct without affecting texture. Elements does not have the "apply image" command (and I cant afford full photoship) which is a crucial step in creating the high frequency (texture) layer. This is a work around.
http://eliaslopez.net/blog/?p=245&cpage=1#comment-159
cspringer Forum Pro • Posts: 19,632
How to separate color and texture
If you set a layer to Color Mode it will only effect the color.
If you set a layer to Luminosity it will only effect the texture.
You can then use the opacity sliders and masks to tweak.
OP gwlaw99 Senior Member • Posts: 1,113
Re: How to separate color and texture
That may be true, but then why do high end retouchers all use frequency separation?
Deleted1929 Forum Pro • Posts: 13,050
Who says they do ? (nt)
StephenG
benross Senior Member • Posts: 1,006
Re: Frequency Separation --apply image work around for Elements
Thank you very much for the tip. This workaround for creating a High Frequency layer in Elements can come very handy at times.
daxx New Member • Posts: 2
hi guys, i would really love to use this work around but it seems the link has been corrupted by some porn site, is there anyway you can send me a new link to this work around. any help would be much appreciated.
kindest regards
john garrett
Spotter Regular Member • Posts: 496
https://www.youtube.com/watch?v=pV-FVMd27h8
Google is your friend.  😄
 Spotter's gear list:Spotter's gear list
Canon EOS 5D Mark II Canon EOS 7D
Well, I can't get the video to run now, but you get the idea.  😄
