14-42 lens
Started May 13, 2012 | Discussions
eliehbk Senior Member • Posts: 1,080
14-42 lens
Well I'm using the kit lens 14-42 I just switched to mft and want to test the camera before investing in lenses. Do you think there is something wrong with the camera?
 eliehbk's gear list:eliehbk's gear list
Sony Alpha a7R II Fujifilm X-Pro2 Fujifilm XF 35mm F1.4 R Sony FE 24-70mm F4 OSS Fujifilm XF 56mm F1.2 R +2 more
greeg Regular Member • Posts: 128
Re: 14-42 lens
I meditated and used my psychic powers for you and can tell you for certain that your camera meets the factory specs.
FlyCBA New Member • Posts: 12
Re: 14-42 lens
I have the GX1 and 14-42X just received from Amazon as the kit. The lens serial number starts with HH1L. It definitely show the blurry effect that is worse with the OIS turned on. Shots taken at 1/30 look MUCH better than shots taken at 1/60 to 1/200 with OIS turned on. Even with OIS turned off the shots at 1/30 look better than shots at 1/60 to 1/200. That was surprising to me. My shots were handheld and zoomed out to 42mm. I shot the same series with the 20mm 1.7 lens which has no OIS and saw the normal shake you would expect at 1/15 to 1/20, clear up at 1/30 and faster. The camera itself is terrific.
Skipper494 Forum Pro • Posts: 11,243
Re: 14-42 lens
Let me think.........NO!
dcassat
dcassat Senior Member • Posts: 1,226
2nd clue please
I'm really ready to help once I figure out exactly what you need to know!
Dan
 dcassat's gear list:dcassat's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Olympus OM-D E-M5 Olympus E-M5 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +8 more
