How to destroy a kodak dcs srl pro sensor! Not yet.
Started May 11, 2012 | Discussions
bassotto Regular Member • Posts: 272
Hi all,
due to the defect of my kodak dsrl pro sensor schott bandpass filter, see my early post, I decided to unglue the bonded filter to change it.
I previously call Midwest repair and ask for a quote to substitute the imager (without sensor board) and they asked me 395,00 $ plus shipping from and to Italy ecc. total cost for me not less than 450,00$.
So my dsrl has already 68000 actuations and altough it is my only digital (I really love it) is a price just high to repair it, I mean not the price from Midwest that I consider low for this repair, but for me.
The story go on, I start to open the camera, eigth screws in the bottom
and two for each side
after I raised a bit the cover and the ribbon connector was pushed gently down
so I could raise the cover and start to remove all the connection
so unscrew the four little screws from the sensor board
to be continued
Gesture Veteran Member • Posts: 7,531
Re: How to destroy a kodak dcs srl pro sensor! Not yet.
Thanks fro sharing. Was the filter material itself degrading? How did you determine that?
OP bassotto Regular Member • Posts: 272
Hi,
the coating of the schott s8612 filter was spotted no clean procedure helps me to get rid of it, the major was inside
Massimo
bassotto wrote:
Hi,
the coating of the schott s8612 filter was spotted no cleaning procedure helps me to get rid of it, the major was inside
Massimo
sorry for bad english
Good luck. Looks like you are half way there.
This is the matter
