Broken red ring on a "L" lens
Started May 8, 2012 | Discussions
jrs024 Junior Member • Posts: 32
The red ring on my 24-105L just snapped off. The lens is 4 years old and in great shape. Have any of you had this issue? If so, have you had a new one put on or did you fix it yourself? If you had Canon fix it, how much did this cosmetic surgery cost?
 jrs024's gear list:jrs024's gear list
Fujifilm X100S Sony RX100 II Canon EOS 5D Mark II Canon EF 16-35mm F2.8L II USM Sigma 50mm F1.4 EX DG HSM +4 more
dgovoni Contributing Member • Posts: 910
Re: Broken red ring on a "L" lens
The same thing happened to mine. To "fix" it you will have to have the lens barrel changed (I called and asked). Not worth it to me. The lens still works without the red ring... :).
dennis
OP jrs024 Junior Member • Posts: 32
Wow, the whole lens barrel has to be replaced to get a new red ring? I figured Canon would be able to send out a ring you could snap on yourself. I think I will leave the lens alone as well, thanks for the advice. The only ā€œLā€ lens characteristic that suffers without a red ring is re-sale value, and I will not be selling that lens.
Earguy Regular Member • Posts: 122
Screw that. Paint pens (white first, then red)...nail polish...peel & stick auto pinstriping...
I was thinking about taking the white ring on my EF-S lens and making it red, just for giggles.
 Earguy's gear list:Earguy's gear list
Canon EOS 5D Mark III Canon EOS Rebel SL1 Canon EOS 70D Canon EF 50mm f/1.8 II Canon EF 24-70mm f/2.8L USM +1 more
Kjeld Olesen Veteran Member • Posts: 3,865
Try this ...
Hank3152
Hank3152 Forum Pro • Posts: 13,499
Re: Try this ...
LOL...........especially the before/after image...........
Hank
 Hank3152's gear list:Hank3152's gear list
Canon PowerShot S95 Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EF 300mm f/4.0L IS USM Canon EF 100mm f/2.8L Macro IS USM +5 more
Re: Try this ...
Really funny, thanks for the advice.
Re: Try this ...
Gary Jean Senior Member • Posts: 2,533
Yes, on two 24-105s. One I sent in for service to check balky AF, barrel play, and eliminate barrel droop. They replaced the red ring as part of the $125 flat rate service. The other remains red ringless.
This has not happened on any other L lens (and I have a bunch) going back to 1998.
BTW, the service was about 3 years ago and the lens is still working perfectly, including no droop.
Gary
http://photo.garyjean.com
Thanks for the reply... In general, how do you like your 24-105. I have considered replacing my 24-105 with a 24-70 f2.8. What do you think?
The only lens I ever sold was also the best zoom I ever owned...the 28-70 f/2.8 L...the predecessor to the 24-70. Why? The extra reach and IS of the 24-105 are just too useful. At f/4.5 it is super sharp. The negs are slight distortion at the extreme ends (correctable) and, of course, loss of a stop.
Before I got the 24-105, the 28-70 was my most used lens. After I got the 24-105, the 28-70 went unused.
The 24-105 is the perfect walk-around lens on FF. Not so on a crop sensor. I never use it on my 7D.
If I can only take one lens on my 5D and 5D III for general purpose people, landscape, street, I take the 24-105.
Thanks Gary, I'm glad I ran into you on this Forum... I will keep an eye out for your posts.
keithinmelbourne
keithinmelbourne Contributing Member • Posts: 885
The same thing happened to my 24-105. It seems to be common. Maybe it means that it is a pretend 'L' after all.
http://www.keithbroadphotography.com/
 keithinmelbourne's gear list:keithinmelbourne's gear list
Olympus TG-5 Olympus E-M1 II Panasonic Lumix DC-G9 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 75mm F1.8 +12 more
Hank3152
I've had two 24-70's over the years and both had electrical/AF issues which were fixed under warranty, but there are many sample variations if you're lucky to get a good one.
I sold both and thought to temporarily try the 24-105 until the 24-70II becomes available and have discovered that I actually enjoy it much more since it has a more useful focal range and IS.
Hank
24Peter
24Peter Veteran Member • Posts: 3,156
Same here: the other day the red ring on my 24-105 L IS just snapped. The lens is about 4 1/2 yrs old.
I'm probably just going to live with it unless the lens needs to be serviced for some other reason.
View my photo galleries here: http://imageevent.com/24peter
Model Mayhem: http://www.modelmayhem.com/93181
Bob Gates
Bob Gates Senior Member • Posts: 1,495
Mine broke off some time ago, and I have now read enough posts about it happening to this lens, but no others, to convince me that it is a design problem. Which means Canon should fix it for free, just as they do mirrors that come unglued.
Bob Gates, Jamesville, NY USA
http://bobgatesphoto.com
 Bob Gates's gear list:Bob Gates's gear list
Fujifilm X-T2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 Fujifilm XF 10-24mm F4 R OIS +2 more
jon lake
jon lake Senior Member • Posts: 1,632
It seems this is not an uncommon problem which seems to target the 24-105 and no other! I remember seeing several posts in the past with this problem. Here is another
http://forums.dpreview.com/forums/read.asp?forum=1019&message=41311123
fortunately, this has not happened to me, but if it did, I wouldn't bother fixing it. I am very happy with the lens, and unlikely to sell it. The red ring means nothing to people if they are not into photography, and I don't see it as a status symbol!
 jon lake's gear list:jon lake's gear list
Canon PowerShot G12 Canon EOS-1Ds Mark II Canon EOS-1Ds Mark III Canon EOS 40D Canon EF 85mm f/1.8 USM +3 more
jon lake
Here is another link
http://forums.dpreview.com/forums/read.asp?forum=1032&message=28791272
