Reversed Zoom Ring
Started May 7, 2012 | Discussions
ajendus Regular Member • Posts: 174
Reversed Zoom Ring
Hello all
A friend of mine, who shoots Canon, complained about my 70-200mm VRII having a reversed zoom ring. Admittedly all my filming lenses are the opposite to the Nikon but I just took it with stride and ran with the reverse on my Nikon lenses.
I'm curious as to why some manufacturers have their zoom rings go one way or the other. Nikon and Panasonic/Olympus lenses are telephoto to wide (left to right) vs. Canon seems to be wide to telephoto.
Any reason one way or the other?
-A
 ajendus's gear list:ajendus's gear list
Nikon D700 Olympus OM-D E-M5 Nikon D500 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 50mm f/1.4G +9 more
Leonard Migliore
Leonard Migliore Forum Pro • Posts: 15,700
Just to annoy us
ajendus wrote:
Hello all
You think you got problems. I own Nikon for amusement and use Canon for work. Everything is backwards. The lenses go on and off backwards, the focus is backwards, the zoom is backwards, the dials are backwards, the buttons work backwards. After a few minutes, I start twitching.
Leonard Migliore
 Leonard Migliore's gear list:Leonard Migliore's gear list
Canon PowerShot G12 Sony RX100 III Nikon D300 Nikon D750 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR +12 more
OP ajendus Regular Member • Posts: 174
Re: Just to annoy us
Just to clarify, I didn't say 'backwards.' I said opposite. I don't perceive one as positive or negative. Nor do I intend to start some sort of silly Canon vs. Nikon argument.
-A
mmullen Veteran Member • Posts: 4,285
Re: Reversed Zoom Ring
ajendus wrote:
Hello all
If you take it to the Southern Hemisphere it will work normally -
Mike Mullen
 mmullen's gear list:mmullen's gear list
Canon EOS 40D Canon EOS 7D Canon EF 85mm f/1.8 USM Canon EF 300mm f/2.8L IS USM Canon EF-S 10-22mm f/3.5-4.5 USM +6 more
Hennie de Ruyter
Hennie de Ruyter Contributing Member • Posts: 785
Mike Mullen
Problem is, here in the south the Nikon works right and the Canon works backwards!
Leonard Migliore
I didn't say which one was backwards
I wasn't claiming either one was wrong. I was just noting that after using one system, the other one is completely reversed from it and it's quite disconcerting.
Leonard Migliore
Peter Jonas Veteran Member • Posts: 3,368
How true.
Peter Jonas
 Peter Jonas's gear list:Peter Jonas's gear list
Fujifilm X-E2 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +1 more
